08-14-2011, 04:58 PM | #1 |
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT Join Date: Jun 2009
FRONT END SHIMMY
I wanted to get some all season tires for my 2010 LT/RS so I could drive when it is wet/raining. So, I bought match pairs of Yokohama parada spec-x. Jacked the car up took off all four wheels/tires off and took them to a local shop that does tires only, to have the yokohamas mounted and balance. I stood there and watch them mount and balanced each one. Came back and mounted them on the car. And,yes I made sure they were mounted in the proper rotation that it said on the tire. I used gorilla locks on all lugs, 20 in all, and torqued to proper specs. About 4 months after that the front end started to shimmy at 60 mph, and it scared the hell out of me. Stopped the car and made sure everything looked right. Which it did. So I think, did the balance wts come off. Took it to the same place, took all four off and the wts were there. So i said lets rebalance them. I stood there and they did and put them back on the car. With the 20 gorilla locks. Drive it up to 60 mph, it was better but not right. So I am like , what the f__k. Thinking the gorilla locks are not holding them right. Went back to the shop and had them put the original OEM lug nuts put on and torqued. Drove , got up t0 65, but still a little shimmy. OK, Everyone, I am lost as to what to check? How about a complete front and back alignment? Need some help here. Everything under the car is correct and in place. Checked it all when we had the wheels/tires off the last time.
Retired Last edited by cowboy1948; 08-15-2011 at 06:50 AM. |
08-17-2011, 12:45 AM | #2 |
Guess no one has any ideas about this???
Retired |
08-17-2011, 03:13 PM | #3 |
Drives: Camaro SS Join Date: Mar 2011
Are the wheels hub centric?
08-17-2011, 06:06 PM | #4 |
I do no undersatnd what that is or means??
Retired |
08-17-2011, 07:49 PM | #5 |
Retired |
08-18-2011, 12:30 PM | #6 |
Doc
Are these stock rims? Or after market? Hub centric would apply to aftermarket rims...its an adapter that fits in the big hole on the rim to adapt to the hub...if that little piece of plastic is missing, you'll get a "shimmy" What did you torque the rims to?
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 1282010 Camaro 2 SS/RS - BLACKOUT & 2017 Camaro 2 SS - 50th Anniversary #894 WWW. NY5THGEN.COM
08-18-2011, 12:32 PM | #7 | |
Retired |
08-18-2011, 12:57 PM | #8 |
I didnt realize you had factory wheels. I was thinking thast you had bought some wheels and tires and was dealing with a vibration.
The biggest variable you have, is assuming that the balancing is being done correctly in the first place.. |
08-18-2011, 12:58 PM | #9 |
If you want, give us a call. Maybe we can play "20 questions" with you on the phone and help you isolate your problem. (631) 957-3901
08-18-2011, 06:55 PM | #10 |
Blown Cool Breeze
Drives: 2011 Black on Black 2SS M6 Join Date: Jul 2010
Find a shop that has a "Road Force" balancer.
It will detect issues with the tire itself which can show it's face after some miles. Sometimes you can rotate the tire 180* on the rim to solve the problem. I say this because you had no issue with the rims before you changedtires. Sometimes the tires won't balance no matter what you do,in which case you contact the manufacturer with your documentation for replacement.
Had a 2010 IBM 2SS M6 Enjoy life.Think of all the women on the Titanic who passed up dessert. |
08-18-2011, 07:11 PM | #11 | |
Thanks for the info..
Retired |
Similar Threads | ||||
Hotchkis versus Pfadt Sway Bars | Avalnch | Suspension / Brakes / Chassis | 78 | 05-02-2018 03:26 PM |
Camaro5Fest III location nomination | Atti2de | 2012 Camaro5 Fest (III) | 2717 | 05-30-2012 11:59 PM |
Next-gen Dodge Viper mule caught wearing new front end | Apex Motorsports | General Automotive + Other Cars Discussion | 10 | 08-16-2011 09:12 AM |
SS sway bars on v6? | jatt5ab1soorma | Suspension / Brakes / Chassis | 9 | 07-07-2011 08:32 PM |
FINISHED THE BUMBLE BEE LOOK FRONT END ! | SILVER BULLITT | Cosmetics and Lighting Modification Discussions | 29 | 08-10-2010 06:28 PM |
