06-23-2011, 10:11 PM | #1 |
My car runs on acorns....
Drives: 2010 SS RS Inferno Orange Join Date: Feb 2010
Gauge advice
Hey all, could use your help again. I think it's about time to put on some guages and could use your advice.
I like the Aeroforce interceptor and PLX dm-100 odb. Are these boost gauges as well, do I need to order a separate line to run to my whipple? Is there a reason you'd recommend one over the other? If they are not boost gauges as well could you recommend one please? Why should I get a wideband guage? Is there any particular need for it, can a scan gauge like those above give me AFR? There seem to be two options for pods, honestly I'm not fond of either (Actually the Nicky Chicago one is bad ass, but can't give up my AC vent.) Autometer and Fesler. Am I missing any? Is either a better product than the other? Thanks for your help folks.
My car runs on acorns, the tears of ricers and these other slightly less important things...
2.9 Polished Whipple, Kooks LT 1 7/8 headers, HiFlow Cats, Kooks Sleeper catback, Cooling Mist Methanol Injection, PFADT Sport Sways, PFADT Springs, PFADT rear trailing arms, ADM intake, JDP stainless brake lines, Jegs Catch can, Stock SS wheels widened to 10 3/4, Hawks HPS Pads, Pedders Rear Subframe Bushing Inserts, BMR Center Brace, MSD BAP, AAC side markers, Emblem Pro's Custom Lighted Door Sills, Dash-Floor-Cupholder ABL lighting and other stuff.... |
06-23-2011, 10:50 PM | #2 |
Boosted Moderator
I have the Fesler dual gauge pod... With the cobalt AEM gauges...
I asked my builder about his recommendations, and I ended up with an analog vacuum/boost and an electronic fuel pressure gauge.. I was told that fuel pressure gauges are more rapid responding and give you an indication of the overall fuel system condition... I'm sure there are arguments for different gauges, but this is why I went the way I did... Try to get a boost gauge that will show your expected peak boost in the middle of the boost section... If you expect to run 8 - 10 psi, then get a gauge that goes to 20 psi... Accuracy is in the middle of any gauge sweep...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
06-24-2011, 09:47 AM | #3 |
Thanks SSE, any opinions on the scanner gauges?
06-24-2011, 09:59 AM | #4 |
Boosted Moderator
I've never used one, but, check with Kyle.gilmour, I think he is using one, not too sure...
06-24-2011, 11:49 AM | #5 |
Drives: 2x 05 Vettes/65'AC cobra/68 camaro Join Date: Apr 2009
we have used and sole the aeroforce for 4-5 years now and they are a AWESOME gauge.
you cannot beat what all they can do. if you want boost you have to buy the separate map sensor and then just input it into the aeroforce gauge and then it will display boost just like anything else on it. the PLX we have also sold for many years and is a good gauge. in all my personal cars i run the dual aeroforce gauges. Let me know if you have any questions about them. |
06-24-2011, 02:52 PM | #6 |
Thanks, called you guys waiting for the price. A pillar pod, dual gauges, boost hookup
06-25-2011, 12:15 AM | #7 |
Drives: ZL1 Camaro Join Date: Feb 2009
if you buy a separate map sensor (3 bar), you need to change some variables in the tune via hp tuners or efi live....
06-25-2011, 03:23 AM | #8 |
I've got mixed opinions on the three bar, my tuner (a very well educated man) kinda laughed when I asked about it, his opinion that unless I was putting out almost twice the power I put down now there was no point.
2.9 Polished Whipple, Kooks LT 1 7/8 headers, HiFlow Cats, Kooks Sleeper catback, Cooling Mist Methanol Injection, PFADT Sport Sways, PFADT Springs, PFADT rear trailing arms, ADM intake, JDP stainless brake lines, Jegs Catch can, Stock SS wheels widened to 10 3/4, Hawks HPS Pads, Pedders Rear Subframe Bushing Inserts, BMR Center Brace, MSD BAP, AAC side markers, Emblem Pro's Custom Lighted Door Sills, Dash-Floor-Cupholder ABL lighting and other stuff.... Last edited by bigsquirrel; 06-25-2011 at 03:23 AM. Reason: drunken grammar |
Similar Threads | ||||
Finally, an A-pillar gauge mount solution for your Camaro @ PFYC - PartsForYourCar | PFYC | Interior Parts & Accessories | 1 | 08-17-2011 03:43 PM |
Custom Painted Inferno Orange 4-Pack Gauge Cluster For Sale | Not Paid 4 | Interior Parts & Accessories | 21 | 11-09-2010 03:56 PM |
AeroForce Interceptor Gauge Install | tjd24 | Audio / Visual / Electronics/ Gauges / Nav | 7 | 10-21-2009 08:38 AM |
New item - Auto Meter ecometer fuel mileage gauge - plug and play @ PFYC.com | Redshift | Audio / Visual / Electronics/ Gauges / Nav | 0 | 07-01-2009 08:56 AM |
SECOND GEN WATER TEMP GAUGE INACCURATE | 79ZRAG | 1st & 2nd Generation Camaros | 9 | 05-30-2009 05:13 PM |
