12-14-2015, 12:58 AM | #1 |
Low oil pressure
Ok so I've noticed lately my oil pressure at idle is low. Before I would see 1.9-2.0bar now I'm seeing 1.4-1.5bar. I'm running the melling oil pump. Only think I've noticed is the lifters sound louder but nothing bad. Holds 3bar oil pressure on the highway.
Car runs fine.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
12-14-2015, 01:42 PM | #2 |
Did the pressure drop right after installing the Melling pump?
Jared Royce 888.308.6007 |
12-15-2015, 02:56 AM | #3 |
No. I've had the pump all summer. Just hear recently I've been seeing the low pressure.
12-15-2015, 04:33 AM | #4 |
Moonshiner
Drives: Holden SS-V L77 flex fuel Join Date: May 2012
Low oil pressure
Is 20 psi at warm idle considered low?
Compression is King.
Naturally as-pirated, all-motor, all alcohol. |
12-15-2015, 06:10 AM | #5 |
Dyno Show Queen LOL
Drives: 16 SS & 17 ZL1 Both Yellow Join Date: Jan 2014
Mine is at 50 psi cold idle then about 37 psi when hot.. but I have a CAM and idle set to 750 rpm With a load its at right 70psi.. thats with a melling high pressure.
This is running the stock mobile oil that it calls for. But, I want to say the pressures were higher a little and there wasn't such a noticeable psi change between hot and cold like there is now. mines been in about a year as well.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber |
03-02-2019, 10:51 AM | #6 |
Drives: '15 ZL1 Join Date: Apr 2017
What came of this? My LSA is running about the same 1.6 bar. Normal?
03-03-2019, 07:07 AM | #7 |
Main bearing failure.
03-03-2019, 08:48 PM | #8 |
Drives: 2012 V6 Camaro 2010 Camaro SS Join Date: Jun 2010
+1 Main bearing failure will eventually happen. When I hear about low oil pressure issues I always wonder what brand and weight motor oil and oil filter people are choosing to use?? I always recommend using Mobil 1 5W30 or Valvoline SynPower 5W30 synthetic motor oil and AC Delco oil filters.
Mr. Clean
03-03-2019, 10:03 PM | #9 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
Having a high pressure pump does nothing for idle pressure. Melling has 3 versions of pumps. Which one do you have? Also when it was installed was it done correctly (shimming while installing)? There could be many reasons for the loss of pressure (pickup tube O-ring, clogged pickup tube, worn pump, bearings, sensor,...) I would get oil analysis done to confirm engine wear before starting any tear down.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
03-03-2019, 10:37 PM | #10 | |
Drives: 2015 1LE Join Date: Oct 2015
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
03-04-2019, 04:20 PM | #11 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
thread revived!
Bone Stock |
03-04-2019, 06:05 PM | #12 |
Drives: Aggressive Join Date: Jul 2008
My Melling just failed last month. Check valve stuck open. Drove from my house to the store, it was fine. When I got back in car and started it, I had no oil pressure.
Black 2SS RS LS3 Inferno Int. '17 1LE replica 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Ideal performance upgraded clutch master cylinder:Tick performance upgraded slave cylinder/throwout bearing: Mantic 9000 twin disk clutch & light weight flywheel: Tuned by Doug Ring at ECS. 475RWHP/445RWTQ.Dynapack Dyno.
03-04-2019, 06:52 PM | #13 |
how long did you have yours before failing. i put mine in last year its been ok so far. I have the high pressure high volume mellings pump. i had 60000 miles when I installed mine.
2012 zl1 stock 7000 miles
2010 TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems. Edit Signature |
03-05-2019, 03:43 AM | #14 |
I had probably 12,000 miles on it. Thank god I was still parked when I was alerted, NO OIL PRESSURE.
