Old 03-12-2015, 04:24 AM   #1
injector
injector's Avatar
Drives: LS3
408 LQ9 build
Dear All,
I am in the process of building an 408 LQ9, which should be ready in couple of weeks. hence, I just want to see if anyone in this forum have worked with such an engine before and knows it's capability.
Just highlights on the long block:
1) callies Drangonslayer crank.
2) Callies Billet H beam rods.
3) -20 wiseco pitons 9:5.1.
4) ARP main and head studs.
5) clevite rod bearing.
6) PRC 260 CC heads.
7) 229/237 .615/.622 116+4
The list goes on.I am satisfied on how the vendor is guiding me through the project. However, wanted to check with you guy if you had first hand experience with such an engine. While doing my research I came to know that this engine has proven itself capable of doing high horsepower under boost. my aim is to live in the 750-850 RWHP via D1sc. As per the parts I have chosen I think I can go a bit higher than my goal (which it is nice to have, but I won't go north of 900 RWHP)
any advise on the build or the limitation of the engine would be appreciated. I have all necessary part ready for when the engine arrives i.e LT, 102 fast intake with TB, ID 850, LPE dual pumps and Alky methanol system.
Thanks guys can't wait for it to be completed.
Texas Speed & Performance Custom Built Forged 408 CID, PRC LS3 260CC,Fast Intake & NW 102 TB, Alky Methanol kit, ID850, LPE Dual pumps,,Melling HV oil Pump. D1SC 10PSI, Stage 2 Air Intake,Magnaflow Axle back, Mcleod clutch, Pedders XA coilovers and sway bars, HD bushings, Hurst shifter, ACS bumper and hood ports, DSS aluminum drive shaft, CSF radiator .
injector is offline   Reply With Quote
Old 03-12-2015, 06:52 AM   #2
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
Well I've seen a 88mm stock lq4 with 317 heads and btr stage 3 turbo hit 850whp on a dyno before and the lq9 built should be able to handle 900whp easy with a proper tune.
Who is doing your tune?
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 03-12-2015, 07:27 AM   #3
injector
injector's Avatar
Drives: LS3
have not decided yet. but I always been getting my car tuned by a friend of mine who is certified and a member of a famous drag team.
Old 03-12-2015, 07:59 AM   #4
Bo White
Bo White's Avatar
Crank that bioch up. You will have to upgrade to a return style fuel delivery though to be safe.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 03-12-2015, 08:57 AM   #5
Ajdin@A2BMotorsport
Yeah anything over 900whp your maxing out the lpe setup
Old 03-12-2015, 09:52 AM   #6
Bo White
Bo White's Avatar
Way below that without meth.
Totalled:
Old 03-12-2015, 10:42 AM   #7
injector
injector's Avatar
Drives: LS3
after i get the car up and running i will be adding squash fuel system
Old 03-12-2015, 11:05 AM   #8
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
cost
If u font mind me asking, what were u quoted as the approximate cost of this engine?
__________________________________________
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is online now   Reply With Quote
Old 03-12-2015, 11:45 AM   #9
injector
injector's Avatar
Drives: LS3
Pm you the cost.
Old 03-12-2015, 12:06 PM   #10
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Engine can take all the power you can make with a DS1 and more. I would ditch the fast intake and put that money towards fuel system or other upgrades. A stock intake will work fine.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 03-12-2015, 04:07 PM   #11
Col. Brain
Drives: 2012 Ram 1980 Malibu
people are making around 1000whp with e85 on bone stock lq4/9s
Id build a stock block car and make sure everything is dialed in before building a forged motor.
Also at 750+ maybe think about moving up to the F1 prochargers?
It will be a beast regardless - good luck with the build
Col. Brain is offline   Reply With Quote
Old 03-12-2015, 04:14 PM   #12
realcanuk
realcanuk's Avatar
Seriously....... way too much internet in this statement.
1000 RWHP on bone stock. I would have to say if you pushed that like it was meant to be pushed, it would not last long.
Old 03-12-2015, 04:49 PM   #13
jrpimp00
jrpimp00's Avatar
Drives: '10 Black/IOM Camaro SS/RS
Not your exact setup but I hit 819 to the wheels in my TA with the setup below: I think youll have plenty more room with that setup then youre looking for. I wouldnt run that FAST intake and put that money elsewhere.
ATK 408
Manley 4340 Forged Crank
Manley H Beam Rods with ARP 2000 Bolts
Manley Forged Skirt Coated Pistons, forgot CC
235/237 115 .610/.610 Cam
ARP Studs
LS6 Intake
S480 on 12psi
Stock 317 Heads with valve job
PRC Dual Springs
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
jrpimp00 is offline   Reply With Quote
Old 03-12-2015, 06:32 PM   #14
Colby627
Colby627's Avatar
Drives: 2010 2SS LSA-S/C 6.6 L
408 LQ9
I have a similar setup, single 82/84 mm top mount turbo, E85 only, have hit 1140 rwhp so far, dialing it down a bit for the texas mile in a few weeks
Colby627 is offline   Reply With Quote
