06-29-2012, 04:35 PM | #1 |
Chief Many Camaros
Drives: A paid off Camaro!!! Join Date: Mar 2009
Track Times
So it's been a over a year since I have been to the track, which was actually at the last C5F in Arizona. I ran pretty consistent around 13 flat.
I am going to a local track tonight and figured the DA was about 7800 ft, since pheonix the I have only added a CAI, trailing arms and catback exhaust. Do you guys think I will still be able to see 13's tonight or should I not set my expectations that high?
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac |
07-02-2012, 05:04 PM | #2 |
Chief Many Camaros
Well it ended up with my best time of a 14.36. Hoped to do better, but oh well.
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac Last edited by K1SSRSS; 07-03-2012 at 08:43 AM. |
07-02-2012, 06:02 PM | #3 |
Drives: 2010 2SS and 2011 LS Join Date: Aug 2011
WOW a DA of 7800....well that explains the time....I thought it was bad here last week at just under 4000.
Around here we like baseball, hot dogs, apple pie, and Chevrolet
07-02-2012, 06:23 PM | #4 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
To OP... have you check out Drag Times DA Calculator? I use it to help me compare my times from one track visit to the next to see if I'm running where I should be despite the weather! http://www.dragtimes.com/da-density-...calculator.php
07-03-2012, 12:59 AM | #5 |
Drives: camaro SS Join Date: May 2012
DA will kill ya. I was up in Albuquerque a couple months ago and the DA was over 9,000.... My runs were over a second slower than when I ran Houston.
Try and keep your head up.. It's really tough at altitude.
