05-31-2010, 10:05 AM | #1 |
Ghostly Unknown
Drives: Silver Ice 2010 SS/RS A6 Join Date: Oct 2008
Torque Specs Needed
Was wondering,does anyone know if theres a thread with all the torque specs on the oilpan,pickup tube,timing cover,valley cover,etc,searched and can't find anything,trying to button up my new motor,so I can get it in the car,Also will it be fine to reuse these bolts,the old motor had 2600 miles on it,I thought there was something posted but just can't find it...thanks
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
05-31-2010, 03:43 PM | #2 |
Ghostly Unknown
nobody?no links?nothing?
05-31-2010, 03:53 PM | #3 |
Camaro➎ moderator
hope this helps, I'll add it to the wiki when I have time.
http://www.camaro5.com/forums/showthread.php?t=63960 |
05-31-2010, 04:22 PM | #4 |
Ghostly Unknown
Thanks bro
06-06-2010, 07:11 AM | #5 |
Drives: Camaro 2010 SS LS7 427ci Join Date: Nov 2009
LS3 torque specs
Go to Lingenfelter Performance web site they have a pdf of all specs.
06-06-2010, 10:32 AM | #6 |
Drives: A wrench Join Date: Jan 2010
Almost all the covers (oil,timing, valley) are 18 ft lbs. If you don't have a TQ wrench that goes that low, you can go by feel and be just fine. Get all the bolts snug down, then another 3/4 turn is about 18 ft lbs. The most important thing is going in a star or criss-cross pattern when tightening the bolts to ensure the covers are sealed properly as your tightening down the fasterners. And yes it's OK to reuse the old bolts. The cover bolts on LS engines are not stretch bolts. Head bolts, cam bolts, and the crank bolt are the only TQ/stretch bolts on the motor.
Similar Threads | ||||
Torque Converters | CamaroSpike23 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 48 | 08-16-2014 02:07 AM |
Header Torque Specs | RickyTheStorm | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 02-14-2010 06:47 PM |
Flywheel Torque Specs? | stangspanker | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 19 | 02-09-2010 09:12 AM |
ANYONE HAVE THE CORRECT TORQUE SPECS FOR RE-INSTALLING FRONT AND REAR SPRINGS | Rick2010 | Suspension / Brakes / Chassis | 1 | 01-15-2010 01:22 PM |
5th Gen Camaro LS3 info from Chevy Hi-Po...READ | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 295 | 03-07-2008 10:06 AM |
