02-04-2014, 03:24 PM | #1 |
Drives: 2010 rs/ss a6 Join Date: Sep 2011
Has anyone port matched tvs 2300 to the heads
Was thinking of port matching the intake on my tvs2300 to the heads. Has anyone done this and did you see any improvement? The ports on the maggie look to be about half the size of the heads but I don't know if that is for a reason. Can anyone help. Thanks
2010 2ss/rs,a6, Hellion top mount twin turbo,rx catch can,zl1 fuel pump,adm fpcm,I.D.850 inj.,ls3 conversion,zr1 3bar map. forged rods&pistons, 160 stat, tuned by T.J.Grimes at Baker Engineering, with his spec cam. BMR suspension upgrades.
02-04-2014, 03:49 PM | #2 | |
When pushing the Maggie above 10 psi it really Helps.
www.jannettyracing.com
02-04-2014, 04:05 PM | #3 |
Bought mine from Ted
Unfortunately I do not have any before & after data as the ported manifold was part of the overall engine build. But it was one of those items I deemed to be very useful in the quest of reducing IATs and exchanging some boost for increased blower efficiency.
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73) CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials |
02-04-2014, 04:12 PM | #4 |
I'am not going to port the heads just open the intake of the maggie to match the heads.
02-04-2014, 04:20 PM | #5 |
The Base manifold was designed to create a swirl affect for Emissions compliance from Magnacharger.
There are Benefits to Port Matching the Base Manifold to the Heads.
02-04-2014, 04:23 PM | #6 |
Thanks for the info Ted. Just so I know I wouln't mess anything up if I do this.
02-04-2014, 04:55 PM | #7 |
Port matching by what I've seen in general is 10+rwhp.
02-04-2014, 06:39 PM | #8 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
02-04-2014, 07:46 PM | #9 |
Drives: 03 vette, 94 trans am, 04 gto Join Date: Jul 2012
We offer porting services on TVS blowers, we have a large portfolio of eaton, tvs, lsa/9 blowers we have ported. If you would like to discuss any of it feel free to call,pm, or email me.
02-04-2014, 07:56 PM | #10 |
Drives: Maggie blown LS3 vette Join Date: Aug 2009
I'm guessing it varies with boost/flow, but do you agree with about a 10hp increase for port matching?
02-04-2014, 08:42 PM | #11 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
I'm doing mine myself this week actually. Not CNC, but it is actually a LOT of material, so I'll be using a fixture on my Bridgeport to get it most of the way, then blending with burrs and sanding rolls. It would take FOREVER with just a set of carbide burrs. I've done a couple on Vettes with the LS3, but this is my first Camaro. Same motor and manifold though. I've seen 10+ hp with no other changes than the manifold. I also saw a drop of about 1/2-3/4 PSI of boost. So slightly more HP with slight less boost, so to me that sound like a gain in effeciency, but I'm no engineer, just a hot rodder.
02-04-2014, 08:56 PM | #12 | |
02-04-2014, 11:36 PM | #13 |
Yes if your just matching it's about 10hp if we do our full port it's around 30
02-05-2014, 07:18 AM | #14 |
Yeah, I'm just matching the lower section to make it rectangle-shaped and lowering the hump at the port floor to give the air a straighter shot, then a little blending. I wish I could CNC them, but at least this way I have almost no money in it, I love that almost free HP!
