Old 04-09-2013, 11:16 AM   #1
TheGreyWasp
Romans 1:16
TheGreyWasp's Avatar
Drives: 2010 Cyber Grey Camaro
acceleration noises
I am having a strange issue when i accelerate from my back wheels/axel. When i hit the gas whether hard of soft i get this distinct crack or click from the back wheels. sounds like something is stuck idk. mayb differential needs to be changed? it only happens when i accelerate. its not te tapping most complain about i know about that. I was told by my dealer months ago that if didnt change my diff fluid my wheels would lock up but i then i read its not necessary. Im just not sure man and its bothering me. im tired of the dealer i take her too they alway try to tell me something else needs to be done.
Romans 1:16
TheGreyWasp is offline   Reply With Quote
Old 04-09-2013, 02:18 PM   #2
Jcobra
Jcobra's Avatar
Drives: 2010 2ss/rs M6
How about going to a different dealer..
Jcobra is offline   Reply With Quote
Old 04-10-2013, 12:01 AM   #3
Avenging Orange
Avenging Orange's Avatar
Change the fluid and see what happens......its cheap.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 04-10-2013, 12:04 AM   #4
DandDC09
DandDC09's Avatar
Drives: '10 2LT/RS, '13 Malibu
I have a clicking noise too.... Mine does it right after I push the gas and right when I let off too... Still haven't figured out what it is! My guess was its in the brake calipers or pads....
DandDC09 is offline   Reply With Quote
Old 04-10-2013, 06:49 AM   #5
bluebox
bluebox's Avatar
Drives: '12 1SS LS3 IBM/SIM
If it's a single crack under heavy load (on or off the gas hard) have them nut-n-bolt the diff and cradle points. Might have been something loosened up or not torqued enough from the factory. If it's a repeated clicking, might be a CV joint. But I'm certainly no expert...
Now: Invo's on Nurburgs | Ext. Eng. catch can | heritage grille
Next: a few Pedders bits, tighten it up | better sways | drop coils, maybe | CAI, exhaust, JRE tune
Then I'm done, I swear.
bluebox is offline   Reply With Quote
Old 04-10-2013, 06:57 AM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
Solid ideas none the less.
Also, if its a chattering type noise, try replacing the diff fluid.
Click to view my build thread
Old 04-10-2013, 08:21 AM   #7
TheGreyWasp
Romans 1:16
thank for the responds fellas! Yea i think im going to just change the diff fluid and take it to the shop have them check the joint and see if anything is loose.
Romans 1:16
Old 04-10-2013, 08:26 AM   #8
TheGreyWasp
Romans 1:16
yep samed exact thing happens. on an off after pushing the gas. are you planning to look into it?
Romans 1:16
Old 04-10-2013, 08:38 AM   #9
Thebabycheech2012
Thebabycheech2012's Avatar
Drives: 2010 ss2 l99
Yea same prob here especially when I reverse and put it In drive I hear a click
Thebabycheech2012 is offline   Reply With Quote
Old 04-10-2013, 09:06 AM   #10
2PitbullSS
2PitbullSS's Avatar
Drives: 2010 Camaro SS & 2003 Z71 w/6" lift
I had this also but had it fixed under warranty. 2010's were missing thrust washers. There is a service bulletin for this issue. Check out the thread below.
http://www.camaro5.com/forums/showth...=thrust+washer
416ci VVT Stroker built by LETHAL RACING
2PitbullSS is offline   Reply With Quote
Old 04-10-2013, 09:12 AM   #11
Thebabycheech2012
I don't trust my local dealer ship they will tell me that it's normal how hard is it to do it my self
Old 04-10-2013, 09:18 AM   #12
Sword5
Sword5's Avatar
Drives: 2010 2SS
Change the fluid. I have a noise from the rear wheels when i accelerate too but it's usually from the tires breaking loose.
It's not hard to do that fluid change by yourself
Ordered 6/19/09 Black on Black 2 SS Delivery 10/14/09! Added CAI, Heritage Grill, DRL Plug and Play Harness
Sword5 is offline   Reply With Quote
Old 04-10-2013, 09:22 AM   #13
Thebabycheech2012
No this thing is a click its not the tires n it only has 20k on the car
Old 04-10-2013, 09:49 AM   #14
TheGreyWasp
Romans 1:16
in the same boat with the dealer. hate goin there! im 40k and out of warranty but they should still change it if it was a recall bulletin. i hope.
Romans 1:16
