04-26-2012, 10:06 PM | #1 |
one wheelin
hope to have my nbm z28 monday
As the title says. and I found I want to get the bfn 3 inch as hood. is it funcional like the stock as hood?
04-26-2012, 10:07 PM | #2 |
one wheelin
This hood.hood.
04-27-2012, 09:13 AM | #3 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
Neither the stock or the VFN is "functional."
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
04-27-2012, 10:01 AM | #4 |
GM Employee
Drives: 2010 Camaro SS/RS Join Date: Aug 2009
you may wanna look again, look at the front of your hood and you will clearly 4 small vents that sits right against the Airbox, as well as the outer grille is cut out/functional, you can make it functional if you really wanted to buy doing some cutting but sometimes its not worth it
Demon your OEM hood should look like this on the bottom while having the vents toward the front near the latch that little "W" section is the functional ram air
2010 Camaro SS/RS - Doug Thorley LT's, SNL V.X Cam/Tune, ADM Cold Air Intake, GMPP Exhaust
04-27-2012, 10:59 AM | #5 |
I'm very familiar with the hood. This is why I put quotations around "functional" as to state it loosely. It's truly nothing to make a difference other than to say it's "functional."
If it worked as a true "ram air," then it would be located at the leading edge of the hood like the WS6 or UltraZ. This is also why the FTRA/SSRA/etc is used and the lower portion of the air box is sealed.
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z Last edited by demonspeed; 04-28-2012 at 11:15 AM. |
04-27-2012, 03:35 PM | #6 |
^ Me. Things I write ~>
I agree with Steve. It might work some, but not like the Firehawk or WS6 hood can. No problem though, just do the free ram-air mod and call it a day.
ndtguy
New DD: 2010 Camaro SS L99/A6 - bone stock. Gone but not forgotten... - 2001 Camaro SS m6 - SLP lid, free ram-air mod, poly sway bar bushings/end links, BMR springs and bilsteins. - 1998 Trans Am m6, forged 347, T70;alky-water injection; intercooled, 208/230 .549/.579 121LSA, Moser 12 bolt, 561rwhp/611rwtq. |
