10-30-2013, 04:17 PM | #1 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Zr1 plugs good or bad
Want to put some zr1 plugs in my build boosted auto making 900 flywheel power on e85 I just glanced through a thread started by supercharged ss that he just blew his second engine caused by the zr1 plug has anyone else had problems with them or what do you recommend.
10-30-2013, 04:27 PM | #2 |
Projected tip + n2o not good. They may work for your application but I prefer something like a tr7ix, 8ix, etc.
Nick
Corvette Z06 -1200ish rwhp |
10-30-2013, 04:29 PM | #3 |
Drives: 2010 Camaro SS Join Date: Aug 2013
Switched out the cold, non-projected tip plugs in my car for the ZR1 plugs and it made a HUGE difference in low speed drivability. Similar power to you, but regular pump gas. With that being said, I don't think I will turn on the nitrous with them in there.
10-30-2013, 04:37 PM | #4 |
Svt lol
I didn't know his entire setup but mine is a street setup not really if any at all no nitrous stuff freaks me out lol.
10-30-2013, 05:03 PM | #5 |
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Is this a serious question? If so they are not a good idea unless you or bolt on or cam only. Use the proper plugs for boost/nitrous unless you want carnage.
10-30-2013, 05:21 PM | #6 |
Svt lol
So the zr1 plugs are no good for boost even though they come in the zr1 that's boosted what would you recommend then, this was a thread to get input to see if anyone had problems with them if so what they went with.
10-30-2013, 05:30 PM | #7 |
Correct. Anyone with these plugs in their zr1 should remove their supercharger immediately.
10-30-2013, 05:36 PM | #8 |
Svt lol
What plugs would you recommend then
10-30-2013, 05:36 PM | #9 |
I'm running ZR1 plugs on 9lb of boost and so are a ton of others. IMO if your going to run less than 10lb if boost they will be fine.
10-30-2013, 05:42 PM | #10 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
10-30-2013, 06:23 PM | #11 | |
Drives: 2010 Camaro Join Date: Feb 2010
My engine gets so pissed that these plugs were used in it that it self destructs!! OP, the ZR1 plugs weren't the sole cause of a popped motors in 2 months. Looks like there are a few reasons but I don't think the ZR1 plugs were helping. I have found nothing, researching spark plugs with boost/nitrous, that remotely says use that plug. Everything points the opposite way. I'm going to believe the major companies like NGK, NOS, etc, when it comes to using the proper plug. |
10-30-2013, 06:35 PM | #12 |
Drives: 2010 Camaro SS / 2006 CC Duramax Join Date: Aug 2009
FYI the ls7 Uses the same plug as a Zr1. It's not a plug designed specially for a boosted application.
10-30-2013, 08:08 PM | #13 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Wassup Sammay!
OP that kind of power you need to run much colder plugs.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
10-30-2013, 08:48 PM | #14 |
Drives: 1999 Trans Am Join Date: Jul 2009
Well, gm has to run a hot plug to pass the government emission tests. They work fine on boosted motors but when you push the motor more the plugs can be an issue. When we do any work to the zl1/zr1 cars the plugs get changed. We notice less knock retard and a bit more power from the tuning we can do with colder plugs.
