11-12-2013, 09:56 PM | #1 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
ID850 injectors stuck in Whipple
I have the Whipple off my car. I need to remove the injectors from the lower manifold. I've twisted and tugged, but they're not coming out. I don't want to break them. The o-rings look squished causing them to be stuck. Any suggestions?
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
11-12-2013, 10:21 PM | #2 |
Guest
Have you sprayed some lubricant around it to help it out?
11-12-2013, 10:23 PM | #3 |
I've tried oil and PB Blaster. Wasn't successful with either.
11-13-2013, 11:42 AM | #4 |
Really, Really Fast
Drives: 2010 Camaro SS Join Date: Feb 2013
center punch?
KIDDING
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
11-13-2013, 12:18 PM | #5 |
Drives: 2011 Synergy Green 1xxxrwhp Join Date: Sep 2012
it should pull out with some muscle, i use the body as leverage on my finger and pull up.... itll take a good tug, i would NOT hit with anything, you are less likely to "rip apart" vs damaging or cracking something with hitting it
11-13-2013, 12:30 PM | #6 |
Guest
I believe i had to damage an oring to get an injector out once. Can you cut, stick the o-ring with a needle or something?
11-13-2013, 01:03 PM | #7 |
I've had several people try to pull them out. No luck yet. I was thinking about heating them up a bit with a heat gun. If that doesn't work, I'll try cutting some of the o-ring. Stock replacement o-rings should work just fine right?
11-13-2013, 01:08 PM | #8 |
Guest
I believe there is only two common injector o-rings, so you should be able to find something to work. I normally use stock ones over what most companies sends.
11-13-2013, 06:45 PM | #9 |
Had to destroy the o-rings, but I finally got them out.
11-13-2013, 06:47 PM | #10 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
I *think* Maggies are supposed to use thinner o-rings than the stock ones but I'm old and forgetz a lot. Maybe that's why they were stuck.
11-13-2013, 06:49 PM | #11 |
Drives: 2010 Camaro Join Date: Feb 2010
11-13-2013, 06:56 PM | #12 |
PHAT B33
Doh... I said I was old....and blind....and can't read.
S'ok, enough people pick on you, you can pick on me.
11-13-2013, 07:02 PM | #13 |
11-13-2013, 07:32 PM | #14 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
Why is the whipple off?
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
