08-03-2015, 02:52 PM | #1 |
Gen 5 Rear Cradle bushing brain fart
While doing a pile of upgrades on a 2010 SS I proceeded to cut out the 4 cradle bushings not realizing I would need to re-use the stock bushing retainers with the new BMR bushings. Let's just say they don't resemble bushing retainers anymore. I've tried to locate new retainers through the dealer and on line with no luck. GM wants to sell me a whole new cradle . I hope there's another option out there short of rolling around a junk yard. Any ideas???
Thanks! |
08-03-2015, 03:00 PM | #2 |
'It's an experiment'
If you can't find any, ADM has the solids for a great price (<$400) I believe -- I don't know of any bushing kits that include the retainers. I'll check my parts manual and see if they are listed...
-Don
747 RWHP 794 RWTQ
08-03-2015, 03:11 PM | #3 |
Does not look like it is sold by itself (pdf parts list):
http://www.camaro5.com/forums/attach...2&d=1276756041 -Don
747 RWHP 794 RWTQ
08-03-2015, 04:14 PM | #4 |
Thanks for the info Don! I'm hoping someone that's put solids in might be interested in selling theirs if there's nothing in the aftermarket. I was surprised I couldn't even find stock bushings for the cradle.
08-03-2015, 06:03 PM | #5 |
old school chevy rodder
talk to six states.... they are the rear end place in the n.w.
08-03-2015, 06:14 PM | #6 |
Are you talking about the white plastic part of the stock bushing? What bushings are you putting in? When I put my BMR bushings in, I had to remove the entire stock bushing, leaving just the metal hole in the sub frame. Did you get the insert version? If you got the Pro version, BK024, the whole thing comes out. If you got the inserts, nothing gets removed at all.
edit - Or are you talking about the metal plates that the bolts go through? Doh. If that's it, then I got nothing for you. What'd you do to them? They come off with the bolts don't they? |
08-03-2015, 06:17 PM | #7 |
I did inserts and did not remove the bushings. If you have complete replacements, I believe Eric is right, you don't reuse anything from the stocks @ all...
-Don
747 RWHP 794 RWTQ
08-03-2015, 06:33 PM | #8 |
I have the pro version. The metal bushing retainer that the bolt goes through was jammed into the factory metal insert so they didn't come off with the bolts. I even pulled on them. I assumed they were integrated into the bushing itself...so I sawed away
08-03-2015, 08:08 PM | #9 |
Drives: 2018 ZL1 A10 Join Date: Mar 2013
I have the pro version. They come with the new center sleeve. Nothing from the stock ones is reused.
Work in progress
08-04-2015, 09:36 AM | #10 | |
08-04-2015, 09:48 AM | #11 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Find someone (junkyard) parting out a Camaro. Even one in a rear end collision should work as long as the washers aren't damaged.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
08-04-2015, 12:44 PM | #12 |
Drives: 2010 ss ls3 6 speed. ips twin turbo Join Date: May 2015
Oh man I just threw some away. I installed solids this weekend. I got the old ones out with heat and didn't damage the metal at all But threw them away sorry man.
