Old 10-22-2013, 01:34 AM   #1
was619
Billy The Kid
was619's Avatar
Drives: Cyber Grey 2SS/RS
LS3 cam, springs etc, single bolt cam gear, and Meling oil pump FS
Did a cam swap selling the parts I swapped.
Almost 43k miles on the car.
Everything is located in north Alabama.
Stock cam $120
Springs, seats, retainers etc $35
I also have the stock pushrods as well if anyone is interested
Meling oil pump- SOLD I bought it off a member a while back. Comes with new seals. It was installed for test fitting only and has some scratches on it from a double roller chain.
LS2 timing chain and
Ls2 dampener both are still in original packaging
$65 shipped
Shipping will be extra depending on where it has to go to, unless otherwise stated.
All items Obo. Message me or post below if interested
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension,
MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners
Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels
was619 is offline   Reply With Quote
Old 10-23-2013, 02:46 PM   #2
was619
Billy The Kid
was619's Avatar
Bump it up
Old 10-30-2013, 10:48 PM   #3
was619
Billy The Kid
was619's Avatar
Bump
The swap is done. I'll post pictures by the end of the week
Old 10-31-2013, 11:04 AM   #4
ROVEGA254
Drives: 2008 Silverado z71
PM sent
ROVEGA254 is offline   Reply With Quote
Old 11-02-2013, 09:10 AM   #5
ROVEGA254
Never mind. I found a cam already. Thanks
Old 11-28-2013, 09:47 PM   #6
was619
Billy The Kid
was619's Avatar
Bump
Old 11-29-2013, 08:24 AM   #7
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Which melling pump is this. The 10296?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 12-01-2013, 01:40 AM   #8
was619
Billy The Kid
was619's Avatar
I'm not sure exactly. The info should be easy to find else where. Last time I looked it up the numbers showed that this model flows much more fluid than a stock or ported unit
Old 12-03-2013, 02:48 PM   #9
rocket69GTP
Drives: G8
Does it come with one or two springs?
rocket69GTP is offline   Reply With Quote
Old 12-05-2013, 05:49 PM   #10
was619
Billy The Kid
was619's Avatar
The stock springs are single springs not double if that's what you mean. Otherwise it would come with 16 of them
Old 12-07-2013, 02:13 AM   #11
was619
Billy The Kid
was619's Avatar
Saturday bump
Old 12-08-2013, 04:43 PM   #12
was619
Billy The Kid
was619's Avatar
Bump it up
Old 01-09-2014, 12:35 AM   #13
Threlkeld's SS
Threlkeld's SS's Avatar
Drives: 2010 camaro ss
Do you still have the oil pump?
Threlkeld's SS is offline   Reply With Quote
Old 01-09-2014, 05:20 PM   #14
was619
Billy The Kid
was619's Avatar
Still available!
