Old 09-18-2017, 11:02 AM   #1
fnhowe84
fnhowe84's Avatar
Drives: 2018 Hotwheels M6 & 2010 1LE V6 M6
aftermarket v8 exhaust on v6
So i cant figure out why a v8 exhaust wont fit on the v6, the mount points are same location. what am i missing? why would i pay more for a v6 version when the 2010 camaro v8 and 6 are the same frame design underneath.
gimme yer 2 cents guys...
thanks!
CamaroLIFE
fnhowe84 is offline   Reply With Quote
Old 09-18-2017, 12:23 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
As far as I know any cat-back for a V8 should fit on the V6, although you might need to adapt to the larger pipes as the V6 pipes are 2.5" between the cats and h-pipe and a cat-back for a V8 may be larger.
KillboyPowerhead is offline   Reply With Quote
Old 09-18-2017, 12:28 PM   #3
fnhowe84
fnhowe84's Avatar
Thats what I thought, the v6 cats are 2.5" just like the v8's. 2.5 down to the H pipe then 2.25 to the rear from what Ive read.... just doesn't make any sense to me to pay hundreds of dollars more because its made for the v6, when its the same application.
CamaroLIFE
Old 09-18-2017, 01:08 PM   #4
bingster223
bingster223's Avatar
Drives: 2015 1LT/RS hot red/black
I remember reading someone put a zl1 npp exhaust on an LS car i think it fit just fine
Sent from my SM-G955U using Tapatalk
bingster223 is offline   Reply With Quote
Old 09-18-2017, 01:11 PM   #5
fnhowe84
fnhowe84's Avatar
I should probably clarify before someone calls me out, from the CAT back, will fit without additional mods like pipe size increaser/reducer
CamaroLIFE
Old 09-18-2017, 01:13 PM   #6
fnhowe84
fnhowe84's Avatar
I can understand someone staying with gm parts but id never get rid of my stock to put back yet another heavy stock part. these damn muff cans are stupidly large.....not much better for the ss cars either with that mid system setup
CamaroLIFE
Old 09-18-2017, 07:47 PM   #7
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
The ZL1 NPP has Quad Tips, that's why people are doing that. They aren't interested in the over all weight of the car.
Eddiefuzz is offline   Reply With Quote
