12-01-2020, 10:10 AM | #1 |
Drives: 2010 Camaro SS Join Date: Nov 2020
Dash Pad removal 2010 Camaro 2SS
I have a 2010 Camaro 2SS that the AC evaporator is leaking. I have disassembled the dash and taken all of the screws that I can think of to try and remove it but it is holding tight on the passenger side. Any ideas?
Do the plastic air ducts under the dash pad come out with the dash pad? I disconnected the side ducts. |
12-01-2020, 10:22 AM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
The HUD installation instructions should get you there.
https://www.camaro5.com/forums/showt...&highlight=hud |
12-01-2020, 01:18 PM | #3 | |
I now have the dash out. |
06-11-2021, 01:14 PM | #4 | |
Drives: chevrolet camaro Join Date: Mar 2020
Hey, I just found this thread. How are you? Do you have any photos of your Camaro to share here? Last edited by jimrhodes; 06-23-2021 at 09:26 AM. |
06-12-2021, 10:56 AM | #5 | |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
to get the evaporator out you have to get the bar out. while i was in there i would replace the heater core and the blend door.
normally you have to remove the windshield but there is a way to do it that avoids that. i used a small air hack saw anything that you can cut the extra length off the bolts with will work. https://www.amazon.com/ACDelco-15-51...s%2C182&sr=8-1 https://www.amazon.com/Spectra-Premi...evrolet+Camaro OR https://www.amazon.com/ACDelco-15-63...evrolet+Camaro |
