03-25-2014, 06:27 PM | #1 |
Man,i dodged a bullet.
So i pull my car out to take these pic's and share of my new spoiler,when i notice oil on the floor. It's like, WTF my car i new.I jack her up to find my oil filter is loose,and see oil dripping down.I haven't driven her in over a week as the stock spoiler has been off and it just looks stupid not having the car complete.I have been waiting on my wrap guy to get the spoiler wrapped.There's a good chance if i had been driving her the filter would of come off while driving.
Now i have always changed my own oil,this being my 1st V8,but changing oil is changing oil.I know the filter needs to be hand tight,but im always afraid of over tightening it.Should an oil filter actually be torqued tight,or just learn from being almost a complete idiot.
03-25-2014, 06:30 PM | #2 |
Drives: 2010 Camaro 2LT RS Join Date: Sep 2012
Hand tight and then a little more, with a filter wrench.
Did you remember to rub. Some oil on the gasket?
If you're not living on the edge, you're taking up too much space.
03-25-2014, 06:40 PM | #3 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
The system I have used for the past 45 years is remove old filter ,check to see is gasket/rubber is stuck on filter, lube new filter gasket ,and hand tighten . Have never had a leak . Strong hands are needed or you may need a filter wrench .YMMV
OLD GUY FLYING FAST AND LOW
03-25-2014, 06:40 PM | #4 |
Yes,i have always done that.
03-25-2014, 06:47 PM | #5 |
run ur car not ur mouth
Drives: 2013 1LE Join Date: Jul 2013
Same as others...hand tight, place some oil on the new filter gasket and there you have it. Now my hand tight is pretty tight.
OAN...what spoiler is that you have? |
03-25-2014, 06:53 PM | #6 |
03-25-2014, 06:56 PM | #7 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Yeah like they said tight plus a little bit more. Oddly I always put them on by hand but usually need filter pliers to get them off.
That looks like a Z/TA spoiler. I just got one too. Maybe not... Sent from my DROID RAZR HD using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
03-25-2014, 06:57 PM | #8 | |
03-25-2014, 06:59 PM | #9 |
That looks real good too,little different lines.What did that run you? With the 20% they give us i was out the door at $255.00
03-25-2014, 06:59 PM | #10 |
Drives: 2014 CRT Convertible ZL1 Join Date: Nov 2013
Don't overtighten but even if you did I'd imagine it would damage the filter not the car.
Sent from my Nexus 7 using Tapatalk |
03-25-2014, 07:00 PM | #11 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
I always hand tighten mine, unfortunately i've had to use the time test screw driver through the filter before to remove one though.
I usually try to get it tight as possible just by hand and that should be good enough.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
03-25-2014, 07:04 PM | #12 | |
03-25-2014, 07:06 PM | #13 | |
Drives: 2017 2SS Join Date: Mar 2012
I have never had an oil filter come lose or leak. You don't want to get one too tight, otherwise you will have a hard time getting it off.
1996 Corvette - LT4
2017 Camaro 2SS 2019 GMC Sierra 2500 HD 2015 Harley Davidson Ultra Limited |
03-25-2014, 07:06 PM | #14 |
For whatever the reason the model # is different then mine though.Mine was like 401110011 not the #350403,but just call them.
