05-12-2011, 02:33 PM | #1 |
Drives: 2010 Camaro 1SS/RS Join Date: Jan 2011
Heads that work well with stock displacement?
Just wondering if anyone out there could point me in the right direction? I originally was not going to purchase heads for my build but after falling 20HP short of my goal, I am reconsidering this option? My only question is which head to choose, or should I just have mine ported and milled? If milled will this cause any clearance issues or issues with the Fast Intake bolting up? The goal is now between 525 to 550 RWHP and 475 to 500 RWTQ! I am currenlty making 481/453! The current list of mods are as followed:
TSP Cam 231/236/TSP Underdrive/Fast LSXr 102 w/Ported Stock TB/ AirAid CAI/ 1 3/4 Pacesetter LT No Cats/ 3 IN MBRP O/R Exhaust/160* T-Stat/Spohn LCA's/ Lethal Performance Custom Dyno Tune=481 RWHP 453 RWTQ!! TSP Cam 231/236/TSP Underdrive Pulley/Fast LSXr 102 w/Ported Stock TB/ AirAid CAI/ 1 3/4 Pacesetter LT No Cats/ 3 IN MBRP O/R Exhaust/160* T-Stat/Spohn LCA's/ Lethal Performance Custom Dyno Tune=481 RWHP 453 RWTQ!! Future mods will consist of 4.11 gears, axles, NT05R's, Barton shifter, 102mm TB, (heads) and a twin disc clutch! Any help or advice would be greatly appreciated!! |
05-12-2011, 03:45 PM | #2 |
Drives: cars Join Date: May 2011
20-30hp is within the abilities of ported heads. If you really want to spend 3k instead of 1k you can get mast heads.
05-12-2011, 03:59 PM | #3 |
I guess what I'm asking is which heads work best with the stock displacement? I don't want a head that flows way too much and actually slow me down instead of helping me. If I do decide to port my stock heads, who can do them and how much would it run me?
05-12-2011, 04:17 PM | #4 |
We carry ported L92/LS3 heads. Excellent flow numbers, they work great with stock displacement. I would recomend adding a cam though.
05-12-2011, 04:30 PM | #5 |
There's a million vendors on here that offer porting services. $900-1500 for ported heads depending on options like springs/valves is typical.
05-12-2011, 04:33 PM | #6 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
Looks like he has a cam.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
05-12-2011, 04:58 PM | #7 |
Drives: 2011 SS/RS LS3 Join Date: Oct 2010
That's a lofty horsepower goal for stock displacement. I would think you would need more compression, a bigger cam, and some bigger primary headers. Alot of $,$$$ for a little power, + you're going to lose some streetability. For that kind of power build a stroker 416" with a bigger cam and it'll still be streetable.... And handle a big shot Ls3 heads aren't exactly the weak point of the engine. jmho
05-13-2011, 09:30 AM | #8 |
Not really, if I am already making 481, I think milling the heads and porting them and the fast intake, will be good for at least 40 rwhp, that puts me at 520, then you add another 10 for the 102 TB, and about 10 more for the electric waterpump and I'm at 540! So what I'm trying to decide is who will port my stock heads, or is there an aftermarket head that will bump my compression to around 11 to 1? Also who can match port the LSXr intake to match my heads for a more precise flow rate?!
05-13-2011, 09:43 AM | #9 | |
Drives: 2011 Camaro SS/RS Join Date: Dec 2010
I have been thinking close to the same and have similar set up as you do. I would think realistic with what you are wanting to add, I could see the set up making 515-525 rwhp at most. In the end you will pay around 1600 for the heads with new valves, and you already have springs. The water pump is around 750-800, the LSX intake and NW 102 are around 1300-1400. Then from what I have gathered to bump compression you will mill the heads and then flycut the pistons, which is $$ not sure how much. But your going to spend close to 6-8K on all this, as minimum. Which is right at territory of a blower and you will get more out of it and you can easly later on sell it. Just a thought, believe me I have been going back and forth with the whole decision which is why I have yet to jump on which route I will take. Good luck in your decision, but you might want to check out a guy on here OrangeSS or something like that, his is a LG car with the G6X3 and is the set up your describing. J |
05-13-2011, 11:14 AM | #10 |
40hp is a lot to expect from porting and milling without an upgrade to a larger cam. Best of luck.
05-13-2011, 11:21 AM | #11 |
Drives: 2012 Chevrolet Silverado 4x4 Z71 Join Date: Dec 2009
Exact reason I went the Maggie route.
Like you,I was seriously considering staying N/A but after comparing cost to horsepower gains S/C was the way to go. Just my opinion. Also,I agree that you may be aiming alittle high on your HP gains after the proposed mods.
SOLD(Traded for 2012 Silverado Z71 4x4 and 2012 Sonic Hatch.)...2010 Camaro 1SS/RS/LS3,yellow with House of Kolor Tangerine Pearl rally stripes,manual trans.Hurst short throw shifter,4 pack rally gauges,Roto-Fab air intake,Kooks long tube headers with high-flow cats,Borla S-Type catback exhaust,Comp Cam,PRC ported heads,Maggie with 3.6 pulley and 1:1 cog drive,secondary fuel system with 65lb injectors,ADM digital A/F and Boost gauge,Pfadt trailing arms and subframe bushings.614.25rwhp/566.82rwtq on 8# of boost.
2012 Chevrolet Silverado 1500 EX.Cab 4X4 Z71. |
05-13-2011, 12:54 PM | #12 |
By simply milling the heads the compression jump is worth at least 10, the ported heads from TSP another 20, and porting the Fast intake should be at least 10 minimum. The TSP heads are 899. the port work for the intake is 125 thru a local shop that did the cam and tune I currently have. The biggest cost would be the waterpump and the NW TB! I like the blower, but it is so much fun to whip up on cars and then just say nope it's all motor, plus if I did have a blower I would def break something!! I did in the past with the bottle!!
05-13-2011, 02:12 PM | #13 | |
Hate to break it to ya, but unless you plan on running them at the track, a blower car will blow you away. That would also be with a set up good tires at the track. Most cars dont just have blowers on them, they have other bolt ons that will put them well over 520rwhp, and will be more like 600+ and in any roll race, which is what you will more than likely ecounter your going to lose that battle. Either way good luck with your goals J |
05-14-2011, 12:56 AM | #14 | ||
Original Bumblebee Owner
Drives: 265hp ZX-14, 500hp Silverado, V-ROD Join Date: Apr 2009
Sorry, don't see how thoses mods will give your stated desired results. It doesn't work this way. You can't just add up the advertised HP gains of various mods and come up with a total HP gain. Even if all the advertised HP gains of each mod are correct (they often are not real world gains anyway), mods don't add up this way when they are combined.
Similar Threads | ||||
WTB: Stock LS3/L99 heads | old motorhead | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 6 | 11-05-2010 06:30 PM |
Anyone have LS7 heads in stock? | jrpxxii | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 09-18-2010 03:45 PM |
how much HP can the stock clutch, axles, and heads handle | mikeSS | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 4 | 09-14-2010 01:33 PM |
Biggest cam for stock heads | Jer4251 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 16 | 03-05-2010 11:27 AM |
ALL Our Camaros are GM Prefer Pricing (old Supplier Pricing) at MacMulkin Chevrolet! | MacMulkin | Dealer Camaros for Sale | 0 | 01-20-2010 06:40 PM |
