11-07-2012, 08:48 AM | #1 |
Drives: 2011 Camaro 2SS L-99 Join Date: May 2012
what size headers should I get for my 2011 camaro SS
My next mod is going to be headers & X-pipe but not sure what kind to get? any suggestions??? I already have SLP loudmouth Axle back & love the sound from SLP But I'm confused on which header to get? SLP headers are 1 3/4 & a few others I looked at were 1 7/8 --- which size should I get?? & does it matter??? Please help! is there a right size or wrong size to fit the L-99 V-8? really could use some input from other 5th gen Camaro owners. Thank U
11-07-2012, 08:52 AM | #2 |
Drives: 03 vette, 94 trans am, 04 gto Join Date: Jul 2012
You will gain some power w/ the 1 7/8 over the 3/4 it's not much on a stock motor but if you ever get buck wild w/ the car they will start showing their advantage down the road. the price difference is very little so why not just get the 1 7/8
11-07-2012, 08:59 AM | #3 |
Romanian Outlaw
Drives: 13 ZL1 , 14 Silverado Crew Cab Join Date: Apr 2010
1 7/8 no doubt!!
[/SIGPIC]2013 Camaro ZL1 M6
11-07-2012, 09:15 AM | #4 |
just can't get enough
How about 1 7/8 stepped... worth it? (like Kooks)
11-07-2012, 09:17 AM | #5 |
1 7//8" have worked amazing on theses motors. You won't lose much running a 1 3/4" header though and the SLP set up is nice because it'll allow you to run a 3" system all the way back. The 1 7/8" headers are also nice because they'll give you some room to grow if you add some more serious mods down the road such as a cam, heads or maybe even a power adder. Just as a heads up... that Loud Mouth axle-back will sound INSANE with headers. Very loud and very raspy.
11-07-2012, 02:45 PM | #6 |
Drives: 2010 RS/SS Join Date: Dec 2010
I suggest 1 7/8" headers as well! As far as brand I definitely recommend Kooks. Great performance and high quality. They are also running a ~$100 off special until almost the end of the month, shoot me a PM if you'd like some pricing!
11-07-2012, 03:00 PM | #7 |
Drives: '69 SS Convertible Join Date: May 2009
If you are buying new then I would go with 1 7/8" and actually I would really consider the 1 3/4" - 1 7/8" stepped headers.
Like others have mentioned there is very little HP difference in 1 3/4" vs 1 7/8". It's only if you end up adding more power adders down the road. On a stock motor I can tell you that I've beaten plenty of other stock motor (even some with a cam) with my 1 3/4" at the drag strip. I have suspension mods though and most other guys I come across with stock motors haven't touched suspension.
Build Journal |
11-07-2012, 03:01 PM | #8 |
All blackkk
Drives: 2010 2SS/RS LS3 Join Date: Oct 2011
size doesnt matter unless ur a pro... you'll never notice the 1-2hp that you'd be missing
Drivin it like I stole it.
11-07-2012, 03:05 PM | #9 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
1 3/4 stepped to a 1 7/8 will technically speed up the air in the tubes but come at a Lil costlier price tag. But IMHO I'd stick to a 7/8's since they are cheaper. Ill be installing 2" TSP headers on my cousins car really soon they cost just the same as their 7/8's so why not. It wil be just a bolt on car..........so far lol.
11-07-2012, 03:06 PM | #10 |
lighten up Francis
Drives: 2013 Camaro 1LE Join Date: Oct 2012
1 7/8's here
1SS 1LE track rat ordered 10/19
Arrived at dealer 12/26/12 after hours delivery |
11-07-2012, 03:23 PM | #11 |
Drives: 2011 Camaro 2SS/RS A6 Victory Red Join Date: Aug 2012
1 7/8" Kooks LT
2011 Camaro 2SS/RS A6/L99 Victory Red
SLP TVS2300 Supercharger 6psi & Coil Covers. Roto Fab CAI. RX Catch can ZL1 Fuel Pump Kooks 1 7/8" LT Headers w/ High Flow Cats Corsa out the back! NT555R 305/35/20 472 RWHP 466 RWTQ 12.11 @ 114.3 MPH 1.81 60' Pacific Raceways Kent, WA 6/6/13 |
11-07-2012, 04:09 PM | #12 |
You will see nice gains with 1 3/4 (in the neighborhood of 30 RWHP and 30 RWTQ) but you will see another 6-7 RWHP and 4-5RWTQ with 1 7/8. The larger the primary diameter gets the more air the headers will flow and the further up the RPM range the power band is moved. This means that generally the more power you make or the more race oriented your application is the bigger primary diameter you need, the closer to stock or the more street oriented the smaller primary diameter you need. In the specific example of the 2010+ Camaro SS, we have found that 1 7/8 long tube headers are a great all around header for the typical bolt on modified car that is driven regularly and occasionally taken to the track. They offer a tremendous improvement over stock with room to grow as owners modify their car further.
11-07-2012, 04:17 PM | #13 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
1 3/4" Tri Y's.... Bottom end Tq is unmatchable.
1 7/8" is the lead that everybody follows too. Can't go wrong either way. Ivan |
11-07-2012, 05:09 PM | #14 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
95% of our header sales are 1 7/8". We also have stepped headers that are the best of both worlds. If you have questions, call us @ the number in the sig. We have helped a lot of customers here.
