03-06-2023, 10:15 PM | #1 |
Drives: 2018 camaro zl1 Join Date: Jan 2023
is this mods good for my zl1?
so im trying to add more power to my ZL1 2018, not too much but on the upper pulley part some people said its bad others dont.
my list of mods that i will do soon - kooks long tube header 2inch no cats -awe touring cat back non resonated -catch can -expansion tank/ overflow tank -2.3 grip tech upper pulley (this one is good?) -hp tuner -flex fuel (whatever percentange i can get with e85) Please guys im new to this tuning and adding more power. i wanna hear opinions of people more experienced than me. is this mods good and wont cause problem for the car in the future????? |
03-07-2023, 06:56 AM | #2 | |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Porting the blower and adding a bigger TB is preferable to spinning the stock blower harder.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
03-07-2023, 07:31 PM | #3 |
Drives: 2022 ZL1 M6 Join Date: Mar 2022
there's no such thing as "bad". Just a different route to go down that may need additional supporting mods to have all parameters run as they should
2022 Black ZL1 M6
RF intake, Soler TB & TC, ADM v2 reservoir, AWE Touring non-resonated catback exhaust. 535 whp, 537 tq. SAE Smoothing: 5. DynoJet. No tune. 91 octane. |
03-07-2023, 07:37 PM | #4 |
Drives: '20 ZLE Join Date: Jun 2020
Ask KingLT1 about what you should do.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
03-08-2023, 07:38 AM | #5 | |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
You're not going to be able to run any ethanol with that set up though. |
03-08-2023, 01:40 PM | #6 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Whats your budget? I would personally keep (2) cats and the stock cat-back to start... If you want more volume, then try the resonated system... As for power, I suggest you look at the JRE 125rwhp package. It's not hard to phase your power adding, but it is easy to make mistakes. If you start with headers, big gulp, boost a pump, E85 + tune, i think you will be a happy camper for a while... Once you get comfortable with that, its as easy as ported blower + 103mm TB + lower pulley and a few other supporting mods.
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi |
03-08-2023, 06:01 PM | #7 | |
Drives: 2019 Camaro ZL1 1LE Join Date: Apr 2018
JRE's package is the cleanest and best way to make quick power for the platform! Additionally, any Non-Resonated AWE systems will be absurdly loud. I had the Track Axle back with just a Rotofab and I had to go back to the suitcase because of the volume. |
03-16-2023, 09:22 PM | #8 |
03-16-2023, 09:52 PM | #9 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
How much power? How much money do you want to spend?
With the LT4, fueling is the most important thing you will do. Direct injection hardware is EXPENSIVE. So figure out your power goal first, then figure out your fueling solution for that power level, and THEN figure out how much bling you can afford after you've blown most of your budget on fuel. You can run E85, but you probably won't want to. The stock fuel system can only spray so much so fast. Most folks run E40-E60 for optimum price/performance. |
03-19-2023, 11:22 PM | #10 |
Drives: 2017 ZL1 Join Date: Aug 2020
He’s trying to tell you the cars stock fuel system won’t support the hp that you’ll make with those mods AND e85. You’ll have to increase fuel delivery with different pumps, injectors, cam.
Tags |
help me i'm a noob, pulley, tuning advice, zl1 |
