Old 06-09-2013, 08:52 PM   #1
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
ZL1 fuel pump question
I may be replacing my axles because of a potential problem with them, figured while that work is being done, if it needs to be done, I will also upgrade the driveshaft and also replace the fuel pump so that I can be ready for any power upgrade down the road. Just in an attempt to save on some labor cost since they will be in there anyway.
My question is about the fuel pump to get. My car is a 100% street car, even if I rebuild or replace my engine, I do not think I will ever be pushing things harder then around 700-750 WRHP at the very most. I already have an MSD volt booster.
My question is will the GM ZL1 fuel pump with the booster safely support this level of power? The cost of this item makes it REALLY attractive compared to the higher dollar pumps. If it will work well, I will go that way, if its questionable, obviously its wiser to spend more to be safe.
Just curious what power level the ZL1 pump with MSD BAP will support safely?
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 06-09-2013, 09:04 PM   #2
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
I'm at 740whp ZL1 Pump/ADM FPCM, BAP, Meth. I don't see any FP drop at WOT. Anything more your pushing it. I'm running a 1 gallon dedicated fuel cell for the 100shot on top.
VanquisherSS is offline   Reply With Quote
Old 06-09-2013, 09:52 PM   #3
Supermaro585HP
Drives: 2011 Camaro SS RS
I have a ADM FPCM that is brand new never opened. I put a ZL1 pump in a couple of months ago and was told I should get it. I'm trading my Camaro in tomorrow on a 2013 60th anniversary Z06 Corvette. Make me a offer.. I think I paid around $200.00 for it. I will look at the paper work tomorrow.. PM me if interested..
Supermaro585HP is offline   Reply With Quote
Old 06-10-2013, 12:31 AM   #4
Slickcas
Drives: 12' 2SS/RS LS3 IBM
I am at at 638 rwhp on my ZL1 pump with no BAP or ADM FPCM. I hold right at 58 psi on my logs all the way to 6600 rpm. I was going to get the ADM FPCM but the tuner said not to it was not needed yet. As there is no pressure drop and the injectors are at 80%+\-.
And just a thought. I am useing a centrifugal supercharger so my power is easer to control. But I will tell ya a 600rwhp street car is a Rocket that will take you straight to the scene of the accident. And the PD Maggie's are worse. You would not think going from 500 to 600+ would be much of a difference but it is on the street. Not saying it not fun lol.
Slickcas is offline   Reply With Quote
Old 06-10-2013, 06:30 AM   #5
Birm
Birm's Avatar
Drives: Florida Speed & Power
I am at 740whp, ZL1 Pump and BAP
Birm is offline   Reply With Quote
Old 06-10-2013, 09:44 AM   #6
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
just got dynoed on thursday and pulled 622whp with no pressure drop at all. Also ZL1 + ADM FPCM.
For the cost of it at $200, its cheaper than any boost a pump out there and its programmed right into the the tune. You really can't beat that.
xjer22x is offline   Reply With Quote
Old 06-11-2013, 03:04 AM   #7
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
Like others have said, if you're getting the ZL1 pump you're good to about 625-650 RWHP, add the ADM FPCM and you'll have no problems at all. Then you just need some ID 850 injectors.
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 06-11-2013, 07:19 PM   #8
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
You say no pressure drop, what was it holding at thru the pull?
Nitroman28 is offline   Reply With Quote
Old 06-11-2013, 08:02 PM   #9
VanquisherSS
You can see a pull I made below and my gauge is in sight. Top right value of the gauge is FP. Holds steady at 58psi lowest I saw was 56lbs for a second.
http://www.youtube.com/watch?feature...6uqIDNns#t=27s
Old 06-11-2013, 08:48 PM   #10
Nitroman28
Nitroman28's Avatar
I dont think that gauge is fast enough to give a good reading. At .38 in the video it showed 54.4, -12.18 boost. That reading was more then likely when you hit 9psi. It showed you didn't hit full boost till the top of the gear. I would hope a centrifugal SC hits full boost faster then that. Not saying your FP is not holding good. Just don't think that gauge is a good way to log it. Reminds me of logging with Torque for the iphone. It only got bits and pieces of data from a run. It would take it 1500+ rpm before it would record new data.
Old 06-12-2013, 12:24 AM   #11
Fiftydriver
Think I am leaning away from the ADM-ZL1 combo and going to save up for the LPE dual pump system. Just to make sure there is no way I will outgrow it as I have not decided yet what I will do for sure for an engine upgrade.
Want to replace the fuel pump only once, its about a $500 bill with my shop to change out fuel pumps so want to do this one time only!!!
Believe the LPE will allow me to do pretty much whatever I want for a practical high performance street car application.
Fiftydriver
More to come!!
Old 06-12-2013, 06:45 AM   #12
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
I AGREE !!!! That's the route I am going. YSI will be going on my car next week. I will go with LPE and be done with it the first time.
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 06-12-2013, 07:35 AM   #13
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Stock L99, ECS kit at 12 psi, LT headers no cats, ID850 injectors, I was seeing pressure down in the upper 40's on a cold day when it was really making power. Warmer days pressure held ok. That was with ZL1 pump and ADM FPCM, and tuned for the ADM FPCM, 6200 rpm shift.
I must add, it was prettymuch ok through a 1 gear pull but on a 1/4 mile pull FP dropped. Would have looked ok on a dyno pull.
I since added a MSD BAP feeding the ADM FPCM and have 63 to 65 psi even on a 100 shot of nitrous and 12 psi. MSD BAP really does alot feeding the ADM and ZL1 combo. Some said it wouldn't help alot but I found it did.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 06-12-2013, 11:01 AM   #14
bct10985
Drives: 2010 2SS LS3, 2013 duramax
I also have the ultraguage and it does seem to be slow on reacting to boost and fuel pressure changes
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
