Old 04-22-2016, 09:38 AM   #1
VASTREETRACER
Drives: 2023 Camaro SS 1LE on order
LS9 to BTR stage 3 PD cam
Just upgraded from the LS9 cam to the BTR stage 3 PD cam. Getting tuned now hope to see some big gains.
2017 Camaro SS 50th anniversary, I sold it but 2010 Camaro SS, whipple, cam, full bolt ons and full exhaust made 739/656 RWHP/TQ on 93 pump gas
VASTREETRACER is offline   Reply With Quote
Old 04-22-2016, 10:43 AM   #2
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
interested
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 04-22-2016, 01:33 PM   #3
old motorhead
Drives: Maggie blown LS3 vette
What is your idea of "big" gains?
old motorhead is offline   Reply With Quote
Old 04-22-2016, 01:50 PM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Excellent question. What's your power level now?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 04-22-2016, 03:53 PM   #5
avido
Drives: camaro ss\rs
i just read an article aboput cam comparative and it shows something interesting.
http://www.hotrod.com/how-to/engine/...r-cams-tested/
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
avido is offline   Reply With Quote
Old 04-22-2016, 05:12 PM   #6
VASTREETRACER
Went from 638rwhp to 686rwhp sae corrected was 701 with standard correction. Tq went down some though I'll post graphs in a few minutes.
Old 04-22-2016, 08:04 PM   #7
VASTREETRACER
This graph has my before and after cam swap numbers. The LS9 cam made 638/571@ 12lbs of boost vs the BTR stage 3 PD cam that made 686/564 at 11.5 lbs of boost.
Old 04-22-2016, 08:27 PM   #8
DrkPhx
DrkPhx's Avatar
Those are stout numbers. Interesting that it lost both hp and tq in the lower rpm range compared to the LS9 cam. It should have picked up power, but it picked up nicely on the top end.
Old 04-23-2016, 01:13 PM   #9
silverz28
Drives: 1996 Camaro Z28, 2012 2SS/RS
why is the torque 100 hp lower?
2012 2SS/RS IOM, LS3, Aftermarket Hurst shifter, IOM interior, Borla "S", 1 7/8 Big Flow headers, ADM Race cold air, BMR 1" lowering springs, SLP Supercharger, Custom Comp Cam, Fore Innovations twin pumps, Flex Fuel Sensor
silverz28 is offline   Reply With Quote
Old 04-23-2016, 02:57 PM   #10
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
It's only 7ftlb lower...
MODS:
Old 04-23-2016, 03:52 PM   #11
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 04-23-2016, 10:05 PM   #12
silverz28
I see what I did there. Anyway, why is the torque 100 lower than the HP?
Old 04-24-2016, 06:02 AM   #13
VASTREETRACER
Not sure
Old 04-24-2016, 08:53 AM   #14
97ChameleonTA
97ChameleonTA's Avatar
Drives: 2013 ZL1 Convertible
Horsepower is a number derived from torque in motion. The formula is HP=(TQxRPM)/5252. That is why you will always see them equal at 5252RPM on a dyno graph.
2013 ZL1 Auto Convertible - BRM
Best: 10.829@127.15
FI Interchiller, Roto-Fab CAI, Big Gulp & Res, 9.1/2.5 Pulleys, PB&S, DeatschWerks 1500cc, Fore triple pump, Pfadt LT's, RD HX, MT DR's
New times to come with E85
2016 2SS Auto - Hyper Blue Metallic
Roto-Fab CAI
97ChameleonTA is offline   Reply With Quote
