06-05-2012, 11:20 AM | #1 |
Drives: 2011 Camaro 1LT Join Date: Oct 2011
Porting heads with a ported IM
I currently have a PTB, 3/8 black iceolator and a plenum spacer. I ordered the ported IM and wanted to know if anyone knows how much of a difference will it be if I don't port match the heads? I know I would have a heck of a time keeping pieces of metal from getting into the heads so I'm hoping to avoid it. On the other hand, I don't want to put everything together and wonder "what could have been", since I don't plan on taking the IM off again once it's on there. Any info anyone has would be great. Thanks
Ben
2011 IOM 1LT RS. K&N Typhoon CAI; Sequential taillights, SLP faded gill overlays, VMAX CNC ported TB, RX Ported IM, RX breather, 3/8" Black Ice-olator, OEM STB, 4 gauge pack, Alpine amp and sub, convertible spoiler, IOM painted rear diffuser, SS front and rear sways, SS front and rear struts and springs, Street Scene front splitter, IOM hideaway headlight covers, 5% window tint.
06-05-2012, 11:32 AM | #2 |
Drives: 2010, 2LT, RS, 6M, ABM (#1893) SOLD Join Date: Mar 2011
check out my thread; http://www.camaro5.com/forums/showthread.php?t=227224
i was going to do this as well, but after marking the ports, there doesn't seem to be much room for improvement. my guess would be 1-5 hp on the top end only. the largest ledge was only .065", and that was only partially around the port. my plan was to put a rag in the port, and then a ball of tape, inside out, that would collect a lot of shavings as well. to me, it doesn't quite seem to be worth the risk for a couple more hp. the 30 or so i am picking up from the spacer/ported IM will be plenty. now if i was going FI i might want to do it??? just my .02! |
06-05-2012, 02:23 PM | #3 |
That's what I was thinking too. Can't wait to get it and put it on now. Thanks for the opinion!
Ben
06-05-2012, 03:13 PM | #4 |
i also came up with a way to get all the bolts in the plenum cover, and the brackets on the back. see my thread soon for the completed install!!!
06-05-2012, 03:47 PM | #5 |
Drives: Summit White 2018 SS Join Date: Feb 2012
It may not be a huge difference but you take off such a little amount to reduce turbulence and it was very easy just put a bit of oil on a rag and stuff it down each hole, tape over the rest, and have someone hold a shop vac while you grind and you're golden i had hardly any shavings left on the rag and those i just sucked up before pulling them out. I recommend it, every little bit counts!
i did a tb/IM/spacer at the same time with the ported heads so i can't tell you the exact gains but it felt a lot more beastly haha |
06-05-2012, 07:48 PM | #6 |
Drives: White M6 1LT RS Join Date: Mar 2010
I ported/gasket matched the IM and Heads all I gots to say is WOW!! The car is fast now. It pulls so hard. I think it makes a difference.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
06-06-2012, 06:10 AM | #7 |
Drives: LLT Machine Join Date: Nov 2011
It will make a little difference but not the same as something like a 5* angle job with full porting of the head, intake, exhaust, bowls.
Jay@Mace USA Velocityport410@gmail.com |
06-06-2012, 07:15 AM | #8 |
It won't make as big of a difference as shaving in your motor will?
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
06-06-2012, 08:49 AM | #9 | |
Ben
