Old 05-02-2013, 09:28 PM   #1
1sikRS
Drives: chevy
ccoling temps.on cammed.ls3 ?
whats average cooling temps in traffic and cruising w a.cam and a 160 tstat
1sikRS is offline   Reply With Quote
Old 05-04-2013, 12:27 AM   #2
1sikRS
Drives: chevy
man noone has a cam here I find that odd
Old 05-04-2013, 12:43 AM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
It shouldn't be any different than a non Cammed car. Are your fan setting set correctly?
Old 05-04-2013, 01:48 AM   #4
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
I agree with Little88, a cam should not make a significant difference in operating temperature. With a proper tune and fan settings there should be no issue. Is your Camaro a LS3 or L99?
LSX Camaro is offline   Reply With Quote
Old 05-04-2013, 07:26 AM   #5
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Because of the fan settings in the tune and 180 deg. thermostat my cammed LS3 runs in general slightly lower cooling temps than when stock. It's usually between 178 and 195. The only time I saw higher than that was last summer I got stuck in traffic at idle for about 15 minutes when it was 110 degrees air temp. I saw the cooling temps climb to 215 but once moving went right back down to 185.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 05-04-2013, 07:56 AM   #6
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Your car will not see less than 176.
Rhino79 is offline   Reply With Quote
Old 05-04-2013, 08:00 AM   #7
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
I have a 160 thermo. Sitting in traffic it gets up to 190. Usually runs around 180. The coldest it gets is 176. May throw 5 degrees on top of those numbers for 90 plus days.
Mchlgrrsn is offline   Reply With Quote
Old 05-04-2013, 08:08 AM   #8
Alvin@PCMofNC
Drives: 2010 IOM RSS
The biggest issue is gm's fan tables start at 192 so there is no way to run the fan earlier than that unless you have them all the time or have the a/c on. So having said that 177-183 at speed and 177-195 ish stopped
Alvin@PCMofNC is offline   Reply With Quote
Old 05-04-2013, 08:10 AM   #9
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Yes run your fans all the time.
Old 05-04-2013, 08:23 AM   #10
Alvin@PCMofNC
I do not reccomend running the fans all the time. The sweet spot for these engines is 180-190 anyhow. Still recommend 160 thermostat
Old 05-04-2013, 12:06 PM   #11
Rhino79
Rhino79's Avatar
EFILive has a fan patch to allow them to operate at lower temps for 160* thermostat setups.
Old 05-04-2013, 02:15 PM   #12
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Learned something new today. Thanx
Old 05-04-2013, 08:49 PM   #13
1sikRS
Drives: chevy
just wondering it climbed to 215 in traffic so I was concerned
Old 05-05-2013, 04:47 PM   #14
Alvin@PCMofNC
215 is a bit high. Where the fans on? Is the coolant full? The upper line isn't hard to bleed but you do have to work the air out of it.
Rhino is right. Efilive does have a patch. I mostly use HPtuners so I didn't even think of that.
