07-12-2016, 07:08 PM | #1 |
Drives: 98z8,10ss Join Date: Apr 2014
1998 z28 h/c camaro 89kmiles
1998 z28 camaro 88,xxx miles. $7000. Consider camper trade. Located in louisville
The car is Ls1/a4 I have owned this car for 11 years and have title in hand. The paint 8/10 (couple small scratches and very small dent on rear quarter) and interior is also car has always been garage kept. Trans was rebuilt 5k miles ago. The car was previously tuned on a little smaller cam and 36# injectors so it really could use another tune, it runs great but I haven't got on the car with the larger cam and injectors . It idles great and everything even have idle clips I can put up if interested. Both windows work great and have newer window motors in them. I can provide more pics or anything else you need. Im sure I am forgetting many details New dd zr1s 17x9 fronts and 17x11 rears. Sumitomo fronts and mickey Thompson streets on rear. Tires still have tags on them also has SLP bowtie front insert on the bumper. 243 heads with patriots 650 lift dial springs. Comp cam 234/238 602 lift 113lsa Hardened push rods comp oil pump ls2 chain. Arp head bolts Tci flex plate Yank 4k stall. Bbk headers Obx catback Electric cutout Stage 1 ported ls2 intake Nick williams 92mm tb Ls2 fuel rail 42 # injectors Racetronix fuel pimp Racetronix fuel pump wiring kit Msd plug Ngk tr6 plugs New water pump New power steering pump lines. Lid Tick performance battery relocation kit. Bmr trunk mount battery tray Sjm abs delete kit Slp line lock Bmr bolt in subframe connectors Boxed hotchkis lower control arms Eibach lowering springs Competition engineering 3 way adjustable rear drag shocks Lokar tranny dipstick Arp flex plate bolts and TC bolts All engine gaskets replaced 1k miles including oil pan gasket and rear main seal. New headliner The bad it could use a tune for WOT but runs fine now like i said i havent got on it since i put the other cam in. sun visors are in bad shape dooesnt have emergency brakes hooked I sold my 9" from it and put a 99z28 10 bolt in that has a 2.73 gear. Line lock needs wired up Text 8125956485. I have tons of videos and pictures |
