08-29-2012, 10:33 AM | #1 |
Drives: 2012 45th Anniversary RS Join Date: Jun 2012
engine light question...
Just poured a can of Torco in my gas tank and now the check engine light has come on.... any worries ? Can I reset the engine light myself ? Thanks.
08-29-2012, 10:41 AM | #2 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
I don't know why that would make it turn on, but NO, you can't reset it yourself.
08-29-2012, 10:42 AM | #3 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
I'd give it some time to go out by itself....I believe it takes it a while to think about things...lol...If no real problem, it will go out on it's own after a while....
08-29-2012, 10:42 AM | #4 |
Drives: 2010 2SS LSA-S/C 6.6 L Join Date: Sep 2011
I have used torco in the past, it is not friendly to O2 sensors , especially wide band sensors for afr gauges, have had to replace the wideband sensor twice
I avoid all octane additives now, running shell 93 octane on 9 psi of boost, and run VP 109 unleaded on 15 pounds of boost |
08-29-2012, 10:43 AM | #5 |
But my check engine light never came on,,
08-29-2012, 11:51 AM | #6 |
Drives: 2010 Camaro SS Join Date: Dec 2011
Avoid all additives in your car. There is no reason to run any additives and gm doesn't recommend it.
2010 Camaro 2SS/RS, L99, OBX Longtube Headers, Magnaflow 3in Comp Cat Back w/ added Dynomax Bullet Race Mufflers, SCT Tuner w/ JRE Tune, CAI Black Intake w/ JRE Race Scoop, Eibach Pro Springs, Custom Sequential Tailights
08-29-2012, 01:08 PM | #7 |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
it will take 50 miles or so to turn back off if that is the problem.
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
08-29-2012, 02:07 PM | #8 |
Not to be obvious but make sure you tightened the gas cap all the way cause that can cause it.
08-29-2012, 02:09 PM | #9 |
it's hers...
Drives: 2011 Camaro 2SS/RS Convertible Join Date: Jun 2012
Thread Tools | |
