08-20-2014, 12:35 PM | #1 |
Drives: E92 BMW M3 Join Date: Oct 2012
+35 RWTQ From a Cam?
So in the spring of this year I got my car dyno tuned on a cold but rainy, humid day and put down 421/417.
I want to get a VERY driver friendly cam with a nice idle(TSP 229/236 type idle), and I want to be at or around 450 RWTQ. Of course more than this would be great, but I am not sure how realistic this is. All the bigger cams I see(NF, G6X3, etc) are putting down less than 450 TQ(430 ish), and are getting great peak HP numbers, which just isn't my goal. This is my DD, and I know low end torque and power are what I will enjoy the most as I cruise from light to light, and just love the choppy sound of a cammed car. Does anybody have thoughts, experience with similar results/goals, or recommendations? Disclaimer: I know dyno numbers aren't everything, but it is a good way for me to explain my goal compared to what other cams put down. I also do plan on getting a custom spec'd cam from Pat G, but not sure if what I want is possible.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
08-20-2014, 12:57 PM | #2 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I see you are already thinking in the proper frame of mind.
For me, it has never been about big #'s on the dyno. Its what makes your car do what you want it to do when you want it to do it. Actually, the TSP cam you mentioned is a good choice. Will you get that magic 450tq? Most likely not...but then again, what good is 450 lbs tq if it doesnt kick in till 5k rpm (being a bit sarcastic, but you get the point). Smaller cam will get you that tq way earlier in the rpm curve....where you need it most. Pat G will do you right. Good luck.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
08-20-2014, 02:12 PM | #3 |
Drives: 2011 LS3 Join Date: Jan 2012
Another good DD cam choice us vengeance vrsp 2. Its a 227/235 grind makes power in the 460s and has a good torque curve.
Stainless Works Headers Vmax TB SLP loudmouth 2 Nightfury Cam Mike Norris CC Tuned by Southwest Speed |
08-20-2014, 02:22 PM | #4 |
This is actually the second one I was looking at. Thanks!
08-20-2014, 02:28 PM | #5 |
That was my original cam of choice. But ended up with the nightfury guess those big peak numbers got the best of me. Overall its a good cam sounds mean and drives great. But id say getting those 450rwtq is gonna be tough on a cam only.
08-20-2014, 02:56 PM | #6 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
My dyno results with night fury:
Headers, CAI, Tune ONLY: 374 rwhp / 395 rwtq With NF Cam: 465 rwhp / 434 rwtq Gain from Cam: 91 rwhp / 39 rwtq I ran 11.91 @ 116mph at the last camaro fest on street tires. This is through an auto trans btw. Last edited by vroomapunk; 08-21-2014 at 10:03 AM. |
Thread Tools | |
