06-26-2015, 01:40 PM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Aug 2012
New cams for big power
I think we all can agree that, as far as off-the-shelf cams go, there are 3 players on the field that have had the highest HP ratings so far:
1.) LG - G6x3 2.) Lethal - Night fury 3.) TSP - 235/239 However, these cams are rather old. Not sure how old the Lethal/TSP cams are... I know a few years... but the G6x3 is at least 5 years old. Are there any newer cams out there that have been proven to make great power for the LS3? (490+ rwhp). I will be camming mine soon and was going to go with the G6x3, but I'm reluctant to install a 5+ year old design in my car.
2010 Camaro 2SS M6
2" Stainless Power Longtube Headers 3" Full exhaust w/ Off-Road H-Pipe Bo White Ported Throttle Body Hurst Short Throw Shifter Best Time: 12.43 @ 114, 1.99 60' on stock wheels and stock tires Build Thread |
06-26-2015, 01:47 PM | #2 |
TEAM NIGHTFURY
Drives: 2010 2SS/RS Join Date: Jun 2014
why change something that works?
06-26-2015, 01:49 PM | #3 |
Drives: 2010 Camaro SS Join Date: Jun 2015
i reviewed alot of cams and i am also going with G6X3 cam with 150 shot. i yet have to find a better cam and i think you posted in the wrong area.
06-26-2015, 01:54 PM | #4 |
Because something that's newer and works better could have come out? Computers from 2005 still work... doesn't mean everyone is going to keep using them when technology has advanced.
This is the V8 Engine, Exhaust and Bolt-On technical discussion sub forum. Not sure what other sub forum it would go in... But thanks on letting me know you're going with the G6x3 as that's my main choice.
2010 Camaro 2SS M6
06-26-2015, 02:10 PM | #5 |
i Understand how you are thinking but you cant compare a PC to metal cams, those cams are the best so far if there was a new cam that was better everyone would know Ls engines are in alot of vehicles, you might find a better software to tune or a better tune, but engine hasn't changed much to find a new cam that will work better.
06-26-2015, 02:22 PM | #6 | |
2010 Camaro 2SS M6
06-26-2015, 02:23 PM | #7 |
All About That Speed
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2013
Depending on how much you're willing to spend, I would check out one of Kip's (CamMotion) low lash solid roller cams. You'll have to upgrade your rockers and lifters.... in addition to the other components you'd have already had to upgrade, but I hear the power is out of this world.
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR |
06-26-2015, 02:25 PM | #8 |
Drives: camaro ss\rs Join Date: Jun 2014
I wouldn't go with lethal. I'm still waiting a response.i had just problem with that company.
06-26-2015, 02:26 PM | #9 | |
2010 Camaro 2SS M6
06-26-2015, 03:01 PM | #10 |
CamMotion does have cams online, but if you call and talk to Kip, he will talk to you, find out what you want, run his magic number and get a cam that will be just what you want.
If you go with the low lash solid roller then you won't have to get the trunion upgrade!
06-26-2015, 03:56 PM | #11 |
Custom cam.
There are new lobes out that may fit your needs better. Cam lobe design does change, and LS cam lobes have come a long way in the past 4-5 years.
Nick
Corvette Z06 -1200ish rwhp |
06-26-2015, 09:10 PM | #12 |
Drives: 2010 ss/rs Join Date: Jun 2013
contact kip at cam motion or martin at tick performance. you can't go wrong either vendor.
rotofab cai
ported throttle body sp headers with cats loud mouth axle back no mufflers tuned by steve williams 6l80etuning.com bmr split springs cam motion custom camshaft btr 660 spring kit maggie 2300 id850 injectors livernois fuel pump |
06-26-2015, 10:29 PM | #13 |
Drives: 2013 SS Join Date: May 2013
Off the shelf cams on the list id go LG anyday. There's more cams out there just not advertised as much these are. A LLSR is hard to beat at 550rwhp with heads not to mention the fastest cars on this list don't run no pre made cams.
06-27-2015, 11:43 AM | #14 |
Drives: 2010 2SS/RS LS3 A6 IOM Join Date: May 2013
I went with Cam Motion and modified LS3 heads, should have some numbers to post next month. ....91 octane and Arizona temps.
Lunati puts down good power and Crower will also grind you a custom cam. |
