Old 01-17-2011, 11:54 AM   #827
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
i think he has something more going on,, just the cai and headers will not cause the issues he is having,, it should still run and drive on the maggy tune,, if it has the correct injectors that came with the maggy,and all the sensors hooked up correct, some ecm data would tell the whole story,,
map reading , maf reading, IAT , LTFT / STFT numbers
Old 01-17-2011, 02:14 PM   #828
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by Russell James View Post
Does P0650 reset if you clear it and then restart and run the engine a couple times?
Is the check engine light working? With those 3 codes it should be on. It should also do a bulb check at first key on.
That MIL code means either there is a problem in the circuit to the MIL lamp, or an ECM problem.
If P0650 comes back after clearing, I think that's the key to whatever is wrong.
It came back on. Very odd.
I'm taking it to J-Ville this weekend. There are NO tuner shops here in lower Bama.
Old 01-17-2011, 02:15 PM   #829
brAnd7onX
brAnd7onX's Avatar
Drives: 2012 1SS IOM
I am spending the day today pounding the pavement to find a tuner here. If I can't, I'll have to go somewhere.
Good luck!
brAnd7onX is offline   Reply With Quote
Old 01-17-2011, 02:15 PM   #830
PQ
Booooosted.
PQ's Avatar
well, you can always put a stock exhaust & intake back on it
just look through the classified threads - i'm sure there's some in there
Right'
I don't know how to data log. And I don't know who to send it to to read.
Old 01-17-2011, 03:12 PM   #831
Russell James
Russell James's Avatar
The tuner is probably going to want to resolve the P0650 issue before tuning. That code means the ECM cannot contol the MIL lamp (check engine) at the proper voltage.
Could be the ignition feed to the ECM or the circuit to the MIL. Possibly one of those circuits got shorted or opened, or pulled out of the ECM connector. If there is no wiring issue, then a faulty ECM. When I googled that code, several sources said a wiring problem is most likely and that is a very rare failure mode for the ECM itself.
I'd suspect that could be related to it not running right. Even with intake and exhaust mods, I would think it should idle fine on a close tune. I've ran mine with open headers before and it idled perfectly on a tune that was done for full exhaust w/cats.
Old 01-17-2011, 03:32 PM   #832
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
And if you search for it here on C5 the only result is this thread... go figure...
Found this thread over on corvetteforum.com, no clue if it will help at all but seems to be a bunch of diagnostic stuff for that code from some internal GM docs
http://forums.corvetteforum.com/c5-t...e-problem.html
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 01-17-2011, 04:02 PM   #833
Russell James
I've got a few service manuals and they all show the MIL circuit as a brown and white wire. Mine are a Vette and Silverado manuals, but I'd suspect Camaro should use the same wire color coding.
I'd trace the wire bundles from the ECM and see if any of the wiring is near where you were working. Maybe a wire got pinched near the fuel rails, things are pretty tight in there. In all the wiring on the engine you touched during the install, see if you can see a brown and white wire. If you find that wire, see if it is pinched anywhere. Also check all the ECM/ignition/engine related fuses.
Maybe one of the ECM grounds lost connection. That main ground on the right head tight? An ECM ground or power feed may make more sense. If it were just a MIL circuit problem, only the code would be the symptom. With that code and an engine performance problem, an ECM problem, ECM ground, or ECM power feed seems to make more sense.
Old 01-17-2011, 04:18 PM   #834
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
isnt' that the wire color you splice into??? for the MAF IAT reading?
or was that blue?
crap... I forgot.
Old 01-17-2011, 04:28 PM   #835
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Isn't J-Ville where GTA lives? Make sure he isn't paying the guy to sabotage your tune. Team LS3 might do that!
Good luck PQ. You are so going to love it when it's finished.
Old 01-17-2011, 04:32 PM   #836
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Nah, the LS3 doesn't need any advantages.
Old 01-17-2011, 04:55 PM   #837
GTAHVIT
Blessed
GTAHVIT's Avatar
Woudl I do that!!!!
I'm gonna make sure my good buddy gets a nice safe tune to ease his mind...
It's not my fault that safe = slow.....
Old 01-17-2011, 04:58 PM   #838
Darth_Emma
Darth_Emma's Avatar
well... alright then...
you only have your friend's best interests at heart... what a guy!
Old 01-17-2011, 05:05 PM   #839
CatiaJockey
CatiaJockey's Avatar
Drives: 2010 2LT RS
Watch him like a hawk PQ! Watch your tuner even closer....
Old 01-17-2011, 05:30 PM   #840
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
...I'm taking it to J-Ville this weekend. There are NO tuner shops here in lower Bama.
i don't necessarily need the truck this weekend if you need it.
Woudl I do that!!!!...
yeppers, you conniving little weasel!
Eve ('00 FRC): hot-air intake
Where to get engine cover modified after a Maggie install? 1meanss Cosmetics and Lighting Modification Discussions 5 03-05-2011 09:00 PM
Another Maggie install .... Luvpilot Forced Induction - V8 9 06-20-2010 09:00 PM
maggie install, hose routing suggestions please n2oSS Forced Induction - V8 6 05-31-2010 03:59 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 04:36 PM
