01-26-2015, 07:04 PM | #1 |
Drives: 2010 2LT Bumblebee Join Date: Apr 2013
What Cats to buy?
So I have emissions coming up this year meaning I got to put some cats in my car soon. I am running Stainless Works headers without cats right now, because with the IPF SC I obviously couldn't have ordered the high-flow cats. I dont want to buy the SW high flow cats and gut them and risk not passing, so I want to know if anyone has bought Cats that can resist the heat of the supercharger. I don't want to use my stock ones because they are welded on to the stock exhaust manifold that I took out and are rusty as hell.
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
01-27-2015, 02:33 AM | #2 | |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
what I would do is empty out your stock cats if you know you won't want to return to stock, and then just put those on if you're trying to pass a visual inspection. if the MIL/CEL matters, get it tuned out. then as long as your state doesn't care about the supercharger you're good and will have more power than with expensive high flow cats hope that helps, my two cents. I will always go against HFC just because catless is better |
01-27-2015, 12:06 PM | #3 | |
01-27-2015, 01:26 PM | #4 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Unless you've already got a check engine light, your tune is taking care of it now (I think all the IPF tunes include that).
If Maryland does a "sniffer" test, you're gonna need to put the stock cats back inline as close to the stock position as possible. I put my stock cats back in with a LT header/no cat tune, and had no adverse effects. |
01-27-2015, 04:37 PM | #5 |
So I guess I'll just take my stock cats and just have a shop cut them off the stock headers and clamp them on temporarily for emissions
