07-02-2020, 10:16 AM | #1 |
Drives: 2011 l99 Join Date: Aug 2012
exhaust clearance
I have a 2011 SS that I have a hybrid Stainless Works exhaust on. I'm having clearance issues where the pipes come together where the bolt in cross brace bolts in the center of the car. Is this cross brace that necessary as when I leave it out the rattling goes away. I'm thinking I know what guys are going to say but just looking for opinions.
07-02-2020, 10:25 AM | #2 |
Drives: 87 Corvette & 2010 SS Camaro Join Date: Feb 2020
Doesn't it hold up the tail of the trans ?
07-02-2020, 11:37 AM | #3 |
Drives: 2011 Camaro 2SS/RS Join Date: Feb 2020
If you're talking about that flat brace under the car that goes from one side to the other and is held on by 4 bolts just leave it off. I have a Kooks exhaust and was told to leave it off and have had no issues. If you want a brace in that location BMR makes a brace that steps down a little bit to clear aftermarket exhausts.
L99 to LS3, Whipple 2.9 Blower with 3.750 pulley, ID1050x injectors, JRE Rough Idle Blower Cam, BTR Bronze Bushing Trunnion Kit , JRE/BTR .660 Springs, BTR Pushrods, Melling High Volume Oil Pump, ZL1 Fuel Pump, JRE FPCM, JMS BAP, JRE 90MM Ported Throttle Body Circle D 3200 Stall Converter, Ceramic Coated Kooks Long Tubes, Kooks Full Exhaust with Hi Flow Cats, Cold Air Inductions Intake With JRE Scoop, JRE Built Rear Differential with Billet Caps, 3:91 Gears and Eaton TrueTrac Posi, JRE Dyno Tune, Moroso Wires, Moroso Catch Can, Factory Reproductions Gloss Black ZL1 Wheels. 659WHP/566TQ
07-02-2020, 12:36 PM | #4 |
Drives: Blaze Red 2014 2SS/RS Join Date: Sep 2016
Or you could just buy some washers and shim the factory brace down....
07-02-2020, 01:03 PM | #5 | |
The BMR cross brace is around $50, so it's not very expensive either.
07-02-2020, 01:51 PM | #6 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
I think the brace is there in case of a side impact so you might want to keep it.
Use washers or buy a brace that has extra clearance for 3” pipes. If you have a 2.5” catback then you shouldn’t need washers or a new brace
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
07-02-2020, 02:46 PM | #7 |
Yeah personally I won't run without it, but at the same time...it's so dang puny.
07-02-2020, 05:25 PM | #8 |
I originally had mine shimmed with flat washers to clear my 3" exhaust but then bought the BMR brace to replace it and it looks really nice up under there.
07-10-2020, 01:54 PM | #9 |
Drives: 2010 camaro ss 2ss Join Date: Aug 2019
I installed an mbrp 3" cat back and it came with a plate that was a step down for clearance
07-10-2020, 06:01 PM | #10 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I just shoved a chunk of heavy rubber in there. Cut up an old sanding block.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
07-10-2020, 06:21 PM | #11 |
Drives: 2SS/RS Join Date: Sep 2008
I have ARH long tubes and 3" cat back and mine cleared no problem. If it's hitting, loosen the flange bolts of the exhaust, push up on the exhaust and re-tighten. There's plenty of room for a 3" exhaust to fit.
07-11-2020, 06:07 AM | #12 |
Scott's45
Drives: 2012 2SS 45th Anniversary Join Date: Mar 2012
pretty sure my stainless works exhaust came with thick washers to solve this problem, it was part of the kit.
2012 2SS 45th Anniversary, Hurst short throw shifter, Stainless Power LT headers, high flow cats, SW Retro Chambered 3" cat back, CAI, Heritage grill, tinted windows, red/silver hash stripes, AAC LED sidemarkers, blacked out turn signals/tail lights, splash guards. 402RWHP
