Old 01-13-2017, 04:38 PM   #1
Dentyneice
Drives: 2010 Camaro 2ss
2010 SS coming out of 3 year storage
I was overseas for 3 years and had the 2010 Camaro SS M6 placed in storage for 3 years. I was able to drive it around for about a week every summer though. The rest of the time it was parked in a normal, non temp controlled storage unit, on a tarp, placed in neutral with no parking break, stabil fuel stabiler, full tank of gas, under a car cover, with the battery disconnected. It has about 60k miles on it.
What all should I do when I take it out of the 3 year storage besides change the oil, oil filter, wash/wax, and air filter? The tires are continental extreme dws and haven't noticed any flat spots on them the past two summers.
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal
Dentyneice is offline   Reply With Quote
Old 01-14-2017, 07:17 AM   #2
JamesMyBoy
Drives: 2014 2SS/RS
If it was me, I'd do all you've said, plus check the coolant to see if it's still good (clean, anti-corrosive properties, etc). Keep a close eye on all the hoses and other rubber parts. I'm sure it still feels like a new car to you, but it is going on seven years old! Wish you the best of luck!
JamesMyBoy is online now   Reply With Quote
Old 01-14-2017, 07:30 AM   #3
dustin0284
dustin0284's Avatar
Drives: 2014 BRM 1LT
That must be a great feeling man!
I'd be taking a cruise around the country!
2014 Camaro 1LT / 2007 Silverado 1500 WT
dustin0284 is offline   Reply With Quote
Old 01-17-2017, 03:12 AM   #4
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
why would you have to replace the air filter? Check anything thats rubber, change oil, How old is the coolant? if its over 4 years id replace it. Id have the battery tested. 3 years sitting in the cold not being charged probably damaged it if it has a charge at all.
JCunningham is offline   Reply With Quote
Old 01-17-2017, 09:21 PM   #5
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
Change Every fluid.
Replace the battery.
Drain the gas tank.
Check the tire pressure but most likely you will have flat spots.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
