Old 02-28-2014, 07:41 AM   #1
Jchuba03
Drives: 2011 1LT/RS IBM
What could this leaking fluid be?
Long story short, went to leave for work, car was running fine, tried turning the wheel, and I itwwouldn't turn. Got out, saw big brown puddle. I am assuming it's power steering fluid, but I'm no expert. It'sunder warrenty, so Im not to concerned, just want to know what it is.
Jchuba03 is offline   Reply With Quote
Old 02-28-2014, 08:05 AM   #2
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Assuming that it is in fact from your car, (I mean did you check under the hood for drips?) it is most likely power steering fluid. Check the reservoir as well to see if it is low or empty.
Only fluids you have are engine oil, tranny fluid (if an auto,) power steering fluid, antifreeze, clutch fluid (if a manual), and brake fluid.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 02-28-2014, 08:32 AM   #3
Jose
Jose's Avatar
Drives: 2010 Camaro 2SS/RS White S/C
Powersteering fluid.
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty
Jose is offline   Reply With Quote
Old 02-28-2014, 08:55 AM   #4
Jchuba03
Its definitely from my car, and I had no check engine lights when I turned it on. Like I said, Only the wheel wouldn't turn. could the reservoir have cracked because of the cold?
Old 02-28-2014, 08:57 AM   #5
Spartan01
Spartan01's Avatar
Possibly, but unlikely. It is proabably a fitting or hose.
Check the Power steering reservoir. Is it low or empty?
If not check your brake fluid reservoir.
Old 02-28-2014, 09:01 AM   #6
Jchuba03
I could see this, maybe a pothole I hit jarred something loose.
Old 02-28-2014, 09:27 AM   #7
Spartan01
Spartan01's Avatar
Possibly.
the hoses are rubber so they tend to wear out faster than the reservoirs.
The fluid appears to have a reddish tint to it, which would lead me to believe it is Power steering fluid, or possibly tranny fluid, but as you said the wheel wouldn't turn, so it is almost guaranteed to be power steering fluid.
Old 02-28-2014, 09:32 AM   #8
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
How cold has it been there in MI?
Last year when it got -28*F here, my power steering hose came loose. There's a TSB on the fluid used. Here's someone else that had a similar issue.
http://www.camaro5.com/forums/showthread.php?t=273366
SPARTAN sui is offline   Reply With Quote
Old 02-28-2014, 10:37 AM   #9
backbaconrules
backbaconrules's Avatar
Drives: 2011 LT Black
My power steering hose went early this winter. If I remember correctly it was an issue known to happen.
backbaconrules is offline   Reply With Quote
Old 02-28-2014, 10:45 AM   #10
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
Loss of power steering fluid would not cause the "check engine" light to come on, even if it went completely dry.
Looks like power steering fluid to me also.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 02-28-2014, 11:06 AM   #11
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
looks like a power steering hose ruptured.
maddoggyusa is offline   Reply With Quote
Old 02-28-2014, 11:09 AM   #12
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
This, or the coupling separated. On the SS cars, the PS cooler hoses are right above the puddle in your photo. There are metal couplings that use a clip to hold them together. If the LT is the same, could be an issue there.
Bye bye, Bumblebee!
Old 02-28-2014, 11:20 AM   #13
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
o well call the dealer they will come and pick it up
JCunningham is offline   Reply With Quote
Old 03-01-2014, 12:34 AM   #14
Blakk11SS
Blakk11SS's Avatar
Drives: 2011 Camaro 2SS/RS
Hi Spartan sui, How's it going up North for you? i hope your repair held thru the brutal cold up there this winter. Believe it or not, after all this cold weather the past 2 months here, the hose repair on the power steering lines made last year are still holding for me, it is amazing! no leaks, and its been down to -20 or so here in Mpls alot.
Blakk11SS is offline   Reply With Quote
