Old 03-16-2014, 08:31 PM   #1
Gi0vanni2ss
Drives: 2010 2ss Camaro
Smile How wide tire will fit factory rim?
Hey all!
i have a 10 SS. I threw on some 1 inch lower Hotchkis springs swaysbars/ end links... now I want to go bigger on rubber in the back on the ss factory rims!
any recommendations on how wide i should or can fit without an issue ?
Factory tire is 275/40-20 ....i was thinking 305- 315.. but will it clear? Also is that too wide? ... car is driven in NY 4 days a week.
THANK YOU IN ADVANCE FOR YOU FEEDBACK AND TIPS!
Gi0vanni2ss is offline   Reply With Quote
Old 03-16-2014, 08:45 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
might have better luck posting this in the wheel/tire subforum
Click to view my build thread
Old 03-16-2014, 09:16 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
+1
I have seen 305's on the stockers but they buldged a bit too much for me. I'm running Conti DWS 295/40's and they fit perfectly. It also depends on the manufacturer. Tire sizes will vary from manufacturer to manufacturer, even with the same numbers.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-16-2014, 09:26 PM   #4
jvoisel
Drives: 2010 2SS/RS M6
I had 315/35/20 nt05r's on my stock 20x9 wheels. Definitely buldged a lot but never had any issues.
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 03-16-2014, 10:15 PM   #5
yellowrs
Drives: 2010 SS 426 V8 M/T
yeah, should be no problems unless you drive off terrain
yellowrs is offline   Reply With Quote
Old 03-16-2014, 10:43 PM   #6
st33v
Drives: 2010 Camaro SS
it's going to look weird. not worth it IMO. but if you decide to get wider wheels put some 315s on that sucker it will look awesome and aggressive
st33v is offline   Reply With Quote
Old 03-16-2014, 10:48 PM   #7
Gi0vanni2ss
Buldged... You mean sticks out the wheel well right? ...
Also, will it fit with the 1 inch drop??
Old 03-17-2014, 01:28 AM   #8
axis
Search Ninja
axis's Avatar
Buldged means the sidewall sticks out past the wheel and tread. Kinda like a muffin top. As for if it will fit, look at your current wheel height to see how much clearance you have between it and the edge of the fender well, then imagine the wheel sticking out past that edge. It may not hit when cruising but i'd imagine it would rub when you hit a good bump. My 295's have never rubbed and they are just inside that lip.
Halltech CF 102 fed
Old 03-17-2014, 08:36 AM   #9
halo8hkk
Drives: 2000 Z28. 2010 1SS IMB.
i ran 295 slight buldge but not to bad.
1990 RS = First Car -SOLD
2000 Z28 = SOLD
2010 1SS/RS = Mysstique
Whipple Supercharger
Dyno= 618hp 555tq at the wheels
IMB Silver Stripes
VIN#44025
Born: 9/9/09 Delivered: 9/28/09
halo8hkk is offline   Reply With Quote
Old 03-17-2014, 09:31 AM   #10
scott's45
Scott's45
scott's45's Avatar
Drives: 2012 2SS 45th Anniversary
Originally Posted by axis View Post
+1
What size are you running on the front?
2012 2SS 45th Anniversary, Hurst short throw shifter, Stainless Power LT headers, high flow cats, SW Retro Chambered 3" cat back, CAI, Heritage grill, tinted windows, red/silver hash stripes, AAC LED sidemarkers, blacked out turn signals/tail lights, splash guards. 402RWHP
scott's45 is offline   Reply With Quote
Old 03-17-2014, 11:45 AM   #11
MrWray
SYBIL
MrWray's Avatar
Drives: 2013 2SS/RS, silver ice metallic
I had to run a stock 20x9 wheel for a couple of weeks, I put my Michelin Pilot Super Sport 315/35 on it and it wasnt bad
MrWray is offline   Reply With Quote
Old 03-17-2014, 05:22 PM   #12
FryZ
Drives: 2011 1SS/RS Synergy Green
305/315 on a stock 20x9 is pointless, IMO...the tire will bulge so much the actual contact patch will be the same as if you were running a 285/295. Can they be put on the rim? Sure, but you aren't going to see any traction advantage over running narrower tires rated to go on stock 9" wheels, and you're spending more $$ for wider tires that won't really work. Again, JMO from trying to run wider tires on the stock 8" wheels on my GTO.
2011 SGM 1SS/RS M6 - E-Force/3.25 pulley - NEP blower cam - Kooks - Borla - ZL1 pump/ADM/ID 850 - RotoFab - Mantic - FR41-275/315 - MGW - Katzkin - tuned by New Era Performance - 650/611
FryZ is offline   Reply With Quote
Old 03-17-2014, 08:26 PM   #13
98GTcoupe
98GTcoupe's Avatar
Drives: 2010 2SS Camaro
Im runnin falken 295/40/20s on the rear, i wouldnt go wider on stockers IMO...
2010 2SS L99 Camaro-TSP headers, Vmaxx TB, CAI, Diablo intune, SOLO Mach X catback, tint, billet custom catch can, SLP Coil covers,SLP lowering springs, 295/40s out back ***SOLD***
Detailed with adams products!
2009 Infiniti G37 Coupe, tint....Stock
2006 GTO, R.I.P.
1981 Z28(sold)
98GTcoupe is offline   Reply With Quote
Old 03-17-2014, 09:47 PM   #14
jbrown13
jbrown13's Avatar
Drives: 2011 Camaro SS L99
Personally, I wouldn't go wider than the manufacturer of the tire you buy says. Tire engineers must have reasons for showing approved wheel widths for the various offerings, and as a retired engineer (not in the tire industry) I would follow those guidelines. I don't know exactly what problems mounting a tire on a wider or narrower wheel creates, but I'm certain it is more than just "looks". You could be creating an unsafe combination. Just MHO and food for thought.
jbrown13 is offline   Reply With Quote
