Old 10-22-2012, 02:09 PM   #1
Bulldogwinters
SS #2431
Bulldogwinters's Avatar
Drives: 2001 Pewter Camaro SS
Oil leak
So I've been leaking oil for quite a while, but recently it seems like it's leaking a lot more. I have to put a quart in before I head home (700 mile trip) or else my low oil light comes on.
I was underneath her yesterday replacing my o2 sensors and snapped a few pictures of where she was leaking from.
This is right at the back of the oil pan. It also seemed like there might be some leaking by the oil filter, but I couldn't tell. Someone at one point told me that it was the oil pan gasket that needed replacing, but I just want everyones thoughts.
Thanks
2001 SS Lid, LT's, 3" Y to 4" Borla XR-1 dumped, LCA, LCA Brackets, Dbl. Adj. Panhard, Subframe Connectors, Shock Tower Brace, Eibach Prokit, Eddlebrock Shocks, C6 ZR1 Wheels 18x9.5
Bulldogwinters is offline   Reply With Quote
Old 10-22-2012, 02:21 PM   #2
naSSty1
Drives: 2010 Camaro SS
Could be the oil pan or a rear seal.
naSSty1 is offline   Reply With Quote
Old 10-22-2012, 02:26 PM   #3
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
I'd agree.
Can you tell if it's coming down from the top of the back of the block anywhere (at the heads, valley cover)?
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 10-22-2012, 03:55 PM   #4
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
rear seal I believe is the issue buddy of mine had this on his 01 SS
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 10-22-2012, 04:02 PM   #5
Stl_Camaro
Stl_Camaro's Avatar
Drives: 12 Dodge Avenger, 02 Trans Am WS6
I'd be willing to bet the real seal as well. But it wouldn't hurt to go ahead and replace the oil pan gasket while you're under there.
Stl_Camaro is offline   Reply With Quote
Old 10-22-2012, 05:43 PM   #6
Bulldogwinters
SS #2431
As far as I could tell it was not coming from the top of the block at all, just seemed to be right there. So i'm seeing the main consensus being rear seal and oil seal. I may just take the car in and have a shop do the work so I don't have to wait till i'm back home on thanksgiving.
Old 10-22-2012, 09:08 PM   #7
demonspeed
demonspeed's Avatar
Drives: Camaros
Rear main seal part number has been updated to reflect the new design: 89060436
10/13/22: 1100
Old 10-22-2012, 09:21 PM   #8
Chevyg1rl
Chevyg1rl's Avatar
Drives: Chevys
I had a drips on my oil filter a couple months ago. It was the rear seal.
Chevyg1rl is offline   Reply With Quote
Old 10-23-2012, 01:38 AM   #9
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
If the whole pan isn't soaked (like mine was..) it's a good chance of a rear main failure. Mine was a hell of a lot worse than this (to the point it coated my Y pipe in oil).
As was said, might as well do both the rear main and oil pan gasket. Also should do poly mounts while you do it because you're gonna have to uncouple the trans and jack the motor up to get the pan to slide back and out.
Zabo is offline   Reply With Quote
Old 10-23-2012, 02:30 AM   #10
Latigo
Drives: Lesbaru Outback
Another POS Camaro shittin oil all over the place!
DON'T KILL ME!
My name's Will and I provided the driveway and some wrench assistance during the O2 sensor swap. Actually looking to get into a Camaro SS or TA WS6 next summer!
Remy, I've done some extra research and it's looking like the rear main may be the culprit; also appears to be the general consensus here. Looks like a pain in the ass to do as well. If you want to weekend tackle this in Missoula or Billings sometime, I'll be happy to lend a hand and some tools. Got an extra couple of jacks in Billings that appear to be required if you only have the one.
Let me know what you wanna do!
Latigo is offline   Reply With Quote
Old 10-23-2012, 12:18 PM   #11
Bulldogwinters
SS #2431
DON'T KILL ME!
Dammit Will. I'll probably get an estimate from a shop around here... and if not I'm gonna be under my car when I'm back in Billings for Thanksgiving(if you're there as well I'll let you know when)
So that's what I'll do, rear seal, oil pan gasket, and poly trans mount
Old 10-23-2012, 01:13 PM   #12
dmginc
dmginc's Avatar
Drives: In Circles
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 10-23-2012, 02:31 PM   #13
Latigo
Well, when the estimates are stratospheric, I'll be standing in the corner with a wrench, a beer and a hammer... maybe just the beer and hammer... that's a lie, probably a martini.
I'll be in Billings most of the break. Only on thanksgiving day will I be down in Wyoming with grandparents and other family members. Any other time though, martini and hammer
Old 10-24-2012, 12:27 AM   #14
Zabo
Gunning for Sixth
Zabo's Avatar
Poly motor mounts too Remy. Motors gotta come off the mounts to slide the pan back and out. Got my set for 75 bucks (motor and trans as a kit) on ws6store.
Shop time on my pan was 5.5, rear main probably another 1.5 and the mounts were.. Mine took 16 hours..
Prepare for them to not line up. Never do.
