#Camaro6
Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro 1LE
AWE Tuning
Old 04-05-2023, 08:21 AM   #1
SMD
Drives: Camaro SS 1le
Does the SS 1LE have the same intank fuel pump as the ZL1?
Does the SS 1LE have the same low pressure intank fuel pump? Was going to go with LT4 high pressure pump and injectors
SMD is offline   Reply With Quote
Old 04-05-2023, 09:15 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
No.
Gunkk is offline   Reply With Quote
Old 04-05-2023, 09:17 AM   #3
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
Yes.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT4 HPFP, LT4 Injectors, JMS BAP - 722WHP
18.2SS.1LE is offline   Reply With Quote
Old 04-05-2023, 11:15 AM   #4
snicko
Drives: 2021 SS 1LE
Based on answers #1 and #2 ... "Maybe" ?
snicko is offline   Reply With Quote
Old 04-05-2023, 12:04 PM   #5
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
I thought the low pressure pumps were the same.
'18 1SS 1LE Black, PDR
Boost Creep is offline   Reply With Quote
Old 04-05-2023, 12:34 PM   #6
truth411
Drives: police interceptor
Yes.
truth411 is offline   Reply With Quote
Old 04-05-2023, 12:35 PM   #7
18.2SS.1LE
18.2SS.1LE's Avatar
It is the same, mine wouldn't be keeping up at this power level.
Old 04-05-2023, 12:41 PM   #8
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I think they upgraded the in-tank pump at some point? Here is a thread that discusses it.
https://www.camaro6.com/forums/showt...ight=Fuel+pump
Mark114 is online now   Reply With Quote
Old 04-06-2023, 09:58 AM   #9
Mountain
Mountain's Avatar
Drives: 2017 SS 1LE, 2016 1SS (previous)
I thought the SS 1LE has the same fuel system back from the engine... Just the HP pump is different... There is an old thread on this somewhere that confirms the exact details.
EDIT: Without searching about for the thread on this, a quick part number search shows that the in-tank pump between SS 1LE and ZL1 are the same. The SS/LT1 has a different pump.
Mountain is offline   Reply With Quote
Old 04-06-2023, 10:44 AM   #10
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
Yes, SS 1LE has the same in-tank pump as the ZL1
Katech_Zach is offline   Reply With Quote
Old 04-06-2023, 12:02 PM   #11
FH212
FH212's Avatar
Drives: 2021 Camaro SS 1LE
OP - there is your definitive answer.
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot
2001 Mecham Trans Am #3 - 7.0L LS1
FH212 is offline   Reply With Quote
Old 04-06-2023, 12:50 PM   #12
SMD
Thank you
