#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
Old 01-21-2024, 09:22 AM   #1
KL01
Drives: Chevy Camaro 2SS
Factory or aftermarket heads???
Looking to get my heads done since I been seeing this stock heads on built bottom end failures. So I was wondering, should I use my factory heads and just send them to get ramped up with all the goodies, or should I just get aftermarket heads.
2019 2SS D1X/CAM/METH/DROP-INS 800whp on 93/ 890whp/670tq C16
KL01 is offline   Reply With Quote
Old 01-22-2024, 05:46 AM   #2
adamjwilson
Drives: 2022 Camaro 2SS A10
What is your budget? Black Mast Heads are one of the best on the market. I wasn't a fan of porting existing stock heads (several places have this service), so I opted for aftermarket heads. Peace of mind more than any real HP gains.
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 01-22-2024, 10:00 AM   #3
Katech_Mike
Drives: 2015 Camaro ZL1
It depends on what you're trying to do.
We offer a CNC service that adds quite a bit of CFM to the factory heads.
You can switch to Ferrea hollow stem intake valves and inconel exhaust valves with a BTR dual spring kit and still be in the $2,200 range for fully ported OEM castings.
Aftermarket castings are going to be $4,000+ typically.
Katech_Mike is offline   Reply With Quote
Old 01-22-2024, 10:14 AM   #4
Slip3Kid
Slip3Kid's Avatar
Drives: 2023 Camaro 2SS
If you go to Pray Performances Youtube channel he has a couple of good videos explaining the good and bad of the stock castings. Worth checking out.
23 2SS M6
1/30 1100
3/23 2000
3/31 3000
4/04 3400 TPW 4/17
4/19 3800
4/20 4300
4/22 5000
4/24 6000
Slip3Kid is online now   Reply With Quote
Old 01-22-2024, 10:25 AM   #5
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
I upgraded my factory heads with Katechs help. I sent them my factory heads because I wanted my build to be number matching still. But don’t care anymore because of my mods have out grown that thought long ago. I got Katech to port the heads in and out, plus hand porting them, new valve job, and got the heads decked. I got them to install my double springs, and smith brothers trunnion kit. (BTR push rods). I went with LS7 performance lifters. I admit I should have went with Johnson Lifters but didn’t.
LT4 1.7 Supercharger snout ported & Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 01-22-2024, 12:52 PM   #6
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
The factory LT4 heads, properly set up will support serious power.
Here is an L8T with Frankenstien ported heads.
https://www.motortrend.com/how-to/sc...-truck-engine/
Stefano is offline   Reply With Quote
Old 01-22-2024, 01:57 PM   #7
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
OP has an LT1. Those heads have been known to suffer from core shift, resulting in coolant leaks on heads that are ported. So agree that the LT4 ones are better but aftermarket will still ultimately have best flow and thicker deck flanges to boot.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
Joshinator99 is offline   Reply With Quote
Old 01-22-2024, 08:07 PM   #8
KL01
I wanted to go all out on the heads. I saw Prays recent post on built bottom end with stock heads failure. Really trying to avoid that. I did get a quote for 2400 for stainless exhaust valve, bronze valve guides, cnc port/polish, hot tank, different seats, mill/decking and new springs. Don't really have a budget in mind, I just don't want the heads to fail me and cause a bigger prob.
Old 01-22-2024, 08:43 PM   #9
Joshinator99
More than I would invest in LT1 heads, IMO….
Old 01-22-2024, 09:13 PM   #10
KL01
What would you recommend?
Old 01-23-2024, 06:43 AM   #11
adamjwilson
Aftermarket Castings of your choosing. Do your research as typical wait times exist for new castings. Its an investment.....
Old 01-23-2024, 09:01 AM   #12
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Stock castings are great if you spend the money to have them totally reworked from the seats forward. The thing is by the time you spend that kind of money, you can get a set of aftermarket heads with a thicker deck. On a NA application not as important as it would be on a big boost build.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 01-23-2024, 10:21 AM   #13
Katech_Mike
Seats chipping and falling out of LT1 heads are 100% related to poor valvetrain control. It's a manufactured issue due to aggressive cam lobes.
We have never failed a seat, intake, or exhaust valve in an OEM LT1 casting. This is across hundreds of in house builds that we've completed since 2014.
You can spend $1,200-$2,000 on porting OEM castings while reusing your intake and exhaust valves and never have a failure if you use the correct combination of parts.
Spend the other 3K on a proper fuel system.
Old 01-23-2024, 10:40 AM   #14
Joshinator99
https://latemodelengines.com/lme-ede...raceheads.html
