02-27-2012, 06:02 PM | #1 |
Drives: 2SS/RS Join Date: Jul 2009
CBI takes on Project "Ricky Bobby"
Not sure if this is the right thread, if not, Mods Please redirect.
Chad Barton CBI Streetcars 314-952-9883 St. Louis MO. I first and foremost would like to give Chad (QuickZOh6) at CBI huge thanks for all of his help in this project. Without his assistance none of this would be possible. He has not only helped me with the decision process on parts but would take the time to explain why he liked one product over the next and what makes it so special. For a first time “Big Project” this meant a lot to me, as it gave me a more in depth understanding of what is really going on. For anyone wanting any kind of work done to your 5th gen, or any performance car for that matter, please do not hesitate to call him. He has been an upstanding guy who holds to his word and is eager to help in any way he can. Oh and his prices aint bad either, lol. The first Part of the process was to look at the foundation. This started with the block and rotating assembly. The Stock GM cube motor I have can handle plenty of power but I wanted more and the comfort of not worrying if I am pushing it too hard. This led me to the GM LSX block. For those who are not familiar with it, it is a Iron Block from GM featuring: • Fully CNC-machined cast iron block • True priority main oiling • 6-head bolts per cylinder • Standard 4.400" bore spacing • Extra-thick Siamese cylinder bores, ready for final honing • Semi-finished, machined thicker decks • LS7-style, 6-bolt dowel-located billet main bearing caps • Wet-sump and dry-sump oiling capability • Production-style deep-skirt head bolt holes • Production bolt hole and thread sizes • Maintains production exterior accessory mounting provisions • Front motor plate mounting holes added • Additional material cast around cam bearings for greater strength • 8mm exterior/interior fifth- and sixth-head bolt holes • All five cam bores machined for bearing P/N 19167218 (supplied) • Standard 0.842" lifter bores • Accommodates all LS oil pumps and oil pans • External oil pump feed (rear of block) • Main web bay-to-bay breathing holes to support greater horsepower • Includes unique cam retainer, rear cover, lifter retainers and production style replacement cam bearings • Front oil feed holes can be plugged/restricted for mechanical flat tappet or mechanical roller lifter applications • Can be machined safely to 9.200" deck height • Maximum 4.200" bore at .200" minimum wall thickness (naturally aspirated applications) • Head bolt holes can be machined for 1/2" studs • Cam bores can be machined to accept 60mm roller bearings • Can be machined for larger diameter lifters and/or 1.060" bronze bushings • Front oil feed lines can be plugged and external oil pump and/or aftermarket dry sump systems can be used via oil pump feed at rear of block-may be required with certain large stroke/aluminum rod combinations • Belt cam drive systems can be accommodated-some machining will be required • Front motor plate can be used for racing chassis applications (sprint car, drag racing, truck pulling, etc.) • Threaded water plugs can be used for external heaters or coolers • Extra stock for main bearing align-honed • Orange Powder Coated And it looks something like this So with the block decided the next step was to determine the rotating assembly. This was a difficult decision because it also determines what if any power adder I would like to do. Originally I was going to duplicate what CBI Chad had in his ZO6 but he suggested we try something different. This suggestion lead to the conclusion of building a 427. The First component I wanted to get for the rotating assembly was the crank. Queue the Dragon Slayer. The Manufacturer low down on the Dragon Slayer goes like this: • DragonSlayer crankshafts are made in the U.S.A. for American Racers. With an expanded line of part numbers, the DragonSlayer is rapidly setting the standard by which other Sportsman crankshafts are measured. • These shafts are machined to the tolerances demanded by today’s high performance engine builder. Roundness and taper are held to less than .0003 on all rod and main journal diameters. Our final polishing procedures produce excellent load carrying surfaces that ensure extended bearing life and trouble free operation. • Each DragonSlayer features the Callies Ultra-Case nitride treatment. This heat treatment method produces a deep case that enhances strength while creating an extremely hard load bearing wear surface. The Ultra-Case process generates a layer of hardened steel deep enough to maintain its integrity even after a -.010 regrind. • Callies heat treat expertise combined with our high purity premium 4340 forging produce strength of unparalleled value Things that I found neat to look at on the crank are The oil Holes in the journals are chamfered to allow for better oiling. That can be seen here where oppose to just a standard hole is used there is a cavity created for oil escape and squeeze between the bearing and journal. For those that don’t know, this is critical because the crank actually rides on a thin film/layer of oil oppose to the bearing itself. Another Beautiful attribute to the crank is the machine work. You can see that this CNC machine carved this out of a block from the bit lines left as seen here. The final point I would like to bring your attention to is the milling of the counter balance on the crank to aid in the crank slicing through the oil oppose to more or less slapping it. The next step was to choose the appropriate rods for the motor. There are many different rod manufacturers and several that have been proven to handle well beyond the limits I would like to push this motor. It came down to three different rods to choose from. The Compustar HD I-Beam, Lunati Pro Billet, and the Oliver parabolic beam Rods. After a few consultations with several different forum members and shops the final decision was made to use the Oliver Rods. They are a 6.125” length with standard Pin and Journal. They look like this, One thing neat that I noticed on the rods that I was not expecting was on the rod bolts. I knew that they were ARP Rods bolts but noticed Oliver had inscribed their logo onto the head of the bolt as well. I wanted to order the pistons next, however, all piston manufacturers wanted to know the cam specs before recommending or designing a piston. No idea where to start on a cam or if I should just use a shelf cam or custom grind I asked the group again and researched as much as I could. All fingers pointed to Pat G. So to Pat G I went and he promptly Spec’d out a cam for my build, and a couple weeks later it was on my door steps. So this is a custom grind cam from Comp with HUC lobes. Yeah, that one took some research and it was pretty neat. The HUC lobes are designed to help settle down the valve train at higher RPM. They change the ramp rate to help set the valve down and pick it up oppose to just dropping it or slamming it shut. This is a glimpse of the Pat G Cam next to a stock GM cam. It is hard to notice a difference at all but it is there. Then on to the Pistons! This is the part that I spent most of my time on and asked the most questions about. These little babies are my pride and joy! Looked at several different manufacturers and settled on JE. After deciding on which supplier to use for the pistons I then had to decide to use a shelf Piston or Custom design a one off set for my application. Reading into Swirl, Quench, Compression, Dish, Dome, and so forth got me dizzy quick. I had decided that I didn’t want to settle or use a piston that would just work so began the process to design or spec out my own piston that was only intended for my setup and my setup alone. I talked to JE several times on the matter and they were great in assisting me as well. The highlights of these jems are: Ceramic thermal barrier tops to help reduce heat from the piston Hard skirt coatings to helps prevent wear and oil hanging on. Thicker Piston walls And lateral gas ports to help aide in sealing in pressure. The vertical gas ports are reported to get clogged, rendering them useless, in street cars. The rest you have to pay to see, lol. The next area for attention was the Pins to hold the piston to the rod. JE had several options with all of their own draw backs and features. I ended up with the upgraded 52 series straight wall pin. They are also made of the thickest material that JE had for this. Nothing special looking but look like this none the less. The ring set recommended to me to use was the Hellfire ring set made by total seal I believe. JE Sent the set along with the pistons. The Second Ring is a Napier cut Ring, look it up. I didn’t get a picture of this as I don’t have a macro lens. The point in the napier cut is a double duty. It will help some with sealing as well as the scrapper design helps remove excess oil from the cylinder wall. This is all I have for now. There are many more things in play but I just choose not to discuss them until they are in my hands. Thank you for reading, and hope you enjoyed and remember, Chad Barton at CBI in St. louis, MO for all your streetcar needs! |
02-27-2012, 06:30 PM | #2 |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
I like it just for the name alone....
Built by Vengeance Racing
9.31@154.81 mph Procharger F1-X RPM Level 7 4L80e + Coan Converter Hendrix 9" Rear Axle + 3.50 Gear ARH 2" LTs+3.5" Exhaust Fore Fuel System, Bogarts + Hoosier Slicks Pfadt Drag Pack Suspension My Build Thread | Best Pass To Date |
02-28-2012, 10:46 AM | #3 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
So you are the one that Chad was talking about when I was there last week. I can tell he is as thrilled to be doing this build for you as you are having him do it.
She is only memory now. Last edited by IndeedSS1; 02-28-2012 at 12:40 PM. |
02-28-2012, 11:46 AM | #4 |
Drives: 2010 Camaro 2SS Join Date: May 2011
Very cool, I will be watching!
Whipple,custom cam,CAI,Kooks,Pedders and PFADT 626RWHP 549TQ ..
02-28-2012, 12:22 PM | #5 |
Drives: 2010 Camaro 2SS/RS - L99 - CGM Join Date: Apr 2010
"hey, horses suck, let's drive cars..." - Ricky Bobby
2007 Corvette Z06 - Velocity Yellow
Halltech | Forgestar | Bilstein |
02-28-2012, 12:42 PM | #6 |
I can't even imagine what would have happened if I had been in something as quick as Bentley's build will be.
She is only memory now. |
02-28-2012, 03:38 PM | #7 |
Drives: 4 wheels Join Date: Oct 2011
Good stuff
I like the details on the pistons, it is obviouse that you did your homework Short pistons, with this skirts, and fat wrist pin makes for one strong piston |
02-28-2012, 03:46 PM | #8 | ||
Thanks again all for the kind words. |
02-29-2012, 08:43 PM | #9 |
Yep I know all about that, not turned correctly boom goes the engine,,, detonation is your enemy,, that I why I am always very conservative on the tune I don't care for the extra 40 ponies when I can't have piece of mind
03-02-2012, 08:09 AM | #10 |
I've had a few people PM me about motors and I keep sending them to Chad even though I went with someone else.
Chad and Dave are a winning team for sure. This car is going to be mean.
Nick
Corvette Z06 -1200ish rwhp |
03-02-2012, 09:17 AM | #11 |
Drives: Love the one you're with Join Date: Sep 2009
That's going to be so mill. I'm tuning in to this one. Be sure to keep us updated.
03-02-2012, 09:40 AM | #12 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Subscribed, thanks for the write-up. I am just starting my planning stages for my 427 build. Trying to decide between ERL or RED sleeved block or the LSX iron block.
Also trying to find someone in Texas willing to take on the build. I will be following this closely, thanks again. What power adder are you planning if i may ask?
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
03-02-2012, 04:59 PM | #13 |
How are you boosting this beast?
03-22-2012, 04:10 PM | #14 |
Crank Balancing
Little update, The short block is being assembled and I was sent a few pictures of the process. The first part being balancing, with the crank already almost being 60lbs and spinning 7000 RPM balance is a good thing. This is a brand new crank, but it is still good to have everything balanced to higher tolerance and ensure all journals are round, not egg or hour glass shaped.
This is the machine used to detect the balance of the crank and through its wizardry tell where weight should be taken away or added. This is the machine with the crank in position to be spun and deciphered by the machine. This is how the balance is displayed on the read out. As can be seen the crank is not in perfect balance and needs to be tweaked. This is the crank in the jig to have a hole drilled for the addition of Mallory. Why Mallory? Mallory is a High Density metal. Mallory is more than twice the density of steel. With the high strength and machine ability it is the ideal material for balancing rotating assemblies. The strength is important because as the crank rotates over 7000 rpm the gravitational force applied to the material can be extreme and cause other materials, like lead, to deform under the pressure. This is the Crank being drilled to accept the Mallory slug. This is the now drilled hole being prepped for the Mallory weight. This is a slug of Mallory that is about to be pressed into the newly created hole. The press having its way with the Mallory slug. The finished slug in its new home. After another spin on the Hines Machine tells us we need to add Mallory to another location as well. And this is the press again doing its work The Mallory again in its new home Finally after another spin on the Hines, we find a perfectly balanced Crank. More pictures to come as the process continues. Thanks, |
Similar Threads | ||||
MBRP Inc & GM project "Colorado Speed" | MBRP Tech | General Automotive + Other Cars Discussion | 40 | 10-08-2010 07:36 AM |
Ultimate Bolt-On Project or Racers Wet Dream? | JusticePete | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 14 | 04-27-2010 04:01 PM |
