Old 10-23-2012, 01:25 PM   #1
06blownSS
06blownSS's Avatar
Drives: 2010 Camaro SS
Negative Camber
Hey everyone,
I tried searching for an answer to this but was unable to find something.
To start, I have the eibach drop on my car and I never did an allignment (yes I know...) the car drives perfect so I never really felt the need to do it.
Only thing is that my rear's (315) have a pretty bad negative camber and I'm eating the inside of my tires so F'n quickly.
Will an alignment with no camber kit fix this? or do I absolutely need a camber kit to correct it.
Thanks for the input!
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, ZL-1 driveline, BTR Stage III Cam, Tuned by Performance Redline 444.1whp & 442.9 ft-lb
06blownSS is offline   Reply With Quote
Old 10-23-2012, 01:55 PM   #2
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
From my research so far with suspension upgrades, it appears that the stock set-up has enough available adjustment to fix the camber. It will probably be addressed through an alignment.
Dexman1349 is offline   Reply With Quote
Old 10-23-2012, 02:15 PM   #3
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Dude, seriously... get an alignment. 59 bucks most places, WAY cheaper than new tires. I have a serious track setup and did not need any additional camber in the rear or front for that matter. The front will likely need some additional caster and Pedders sells an eccentric bolt for that but it does require some grinding. An alignment will solve your tire wear issue.
jeremywes is offline   Reply With Quote
Old 10-23-2012, 03:21 PM   #4
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
With the 315s negative camber wears the inner shoulder very quickly. Ideally you should be at -0.50. Have the tech try to get as close to that as possible with the OE eccentrics. Have him set the toe eccentrics to a neutral position and then set the camber. The toe and camber eccentrics work against each other like an old school wishbone or A arm. Post your alignment specs here when you get done.
Old 10-23-2012, 04:42 PM   #5
06blownSS
06blownSS's Avatar
In my neck of the woods alignments are closer to 100$, and from experience with shops around here everytime I've gone in for one I came out regretting it. This is why I have avoided it this long. But yes your right alignment>new tires every season.
Thanks for the advice JusticePete, I will definitely tell them to aim for -0.50. I will have to find a shop around here that will do it properly.
Old 10-27-2012, 03:02 PM   #6
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Try a local Firestone. They usually have newer equipment and if you can find a competitors coupon they will honor it for a cheaper price.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
