03-31-2016, 07:08 PM | #1 |
Drives: 2015 camaro 1ss Join Date: Dec 2015
Lsa Quarter mile times?
Im just wondering about what my car should run in the quarter mile i have,
lsa blower with 2.55 pulley brian tooley stage 3 pd cam 1 7/8 headers no cats jlt cold air tci 28-2900 converter adm fuel pump module and zl1 pump 89 lb injectors |
03-31-2016, 07:14 PM | #2 |
Drives: 2011 Camaro 1SS Join Date: Feb 2016
11.2
*DISCLAIMER* the above number is made up as we have no idea given the info you gave us. Suspension, tires, drivers skill and more factor in as well. |
03-31-2016, 07:40 PM | #3 |
On drag radials stock suspension.
03-31-2016, 08:30 PM | #4 |
Drives: 2015 Yellow 2SS LT Z28 cai tune Join Date: Aug 2015
11.90
04-01-2016, 07:27 AM | #5 |
IL part the car out if it only runs a 11.90
04-01-2016, 07:43 AM | #6 |
650,whp on street tires
Ran a 12.2 @126 2.2 60ft
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
04-01-2016, 08:32 AM | #7 |
I have first dibs on the rear diff.....
All kidding aside, take it out and see what you do but leave your expectations at home.
04-01-2016, 10:21 AM | #8 |
I wouldn't take it to the drag strip on street tires
04-01-2016, 10:43 AM | #9 |
I would guess 11.80-12.2 depending on conditions and how well you hook. PD blowers are a blessing and curse being as you have the torque at your fingertips. Good luck man and be safe.
04-01-2016, 05:05 PM | #11 |
Drives: 2012 Camaro 1SS with Turbonetics Join Date: May 2014
I'm going to predict a 10.9 at 126 mph with traction. You and I are probably at similar hp levels.
Thanks, Kevin
2012 1SS...in the 10's...but not fast enough yet.
04-01-2016, 05:54 PM | #12 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I'm going to say 11.50s
04-01-2016, 09:57 PM | #13 |
Drives: T Join Date: Mar 2015
you have the mods for power to run 10's.
What suspension and wheel tire setup are you using? That is going to determine more of what your potentially going to run. |
