03-12-2014, 11:48 AM | #1 |
Drives: 2013 Camaro 2LT/RS Join Date: Oct 2013
RPM Question
So I have an MRT 2.0 installed and get some crazy drone when cruising on the highway from 70-75 (1900-2000RPMS).
I figured out that if I through it into S mode and leave it in 5th gear (2500RPMs) the drone goes away and the sound is much more bearable. Is there any harm in running it like that on the highway? Thanks!
03-12-2014, 12:23 PM | #2 |
Drives: 2012 IOM 2LT RS A6 w/ BA Join Date: Apr 2013
A little more wear, and a little more gallons per mile. ;-p
Some people add an X-pipe, I went with J-pipes.. 0 drone from 70-80 on freeway.
ToDones -
Apex Scoop & Washer Relocate - CAI cai - Elite CC - Elite Clean Side Separator - MRT v1 Axle Back customized w/ J-Pipes - Black Out Headlight/Tail Light - Black Out BowTies - Black Out 'camaro' - Black Out Brake Light Chrome Bezel - JL Audio XD400/4 - Sub Thump Sub Box 2 DVC 10"s - HIFONICS ZEUS 1000.1 Escort Redline - VIOFO Dash Cam - Continental Extreme Contact Tires Gary's Customs ZL1 Front Bumper, ZL1 Rockers, & ZL1 Spoiler - Paint matched IOM OverKill 80mm T-body - JacFab Ported Intake Manifold - JacFab Extendolator 3/4" Spacer ToDos - Tune? |
03-12-2014, 12:42 PM | #3 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Yeah, you'll just kill your highway mileage. As Kessler did, I recommend the resonated x pipe. It seems to fix it for most people.
03-12-2014, 04:32 PM | #4 |
I've got the x-pipe but no resonators
i might try to throw some stock resonators back on.
03-12-2014, 06:39 PM | #5 |
KaBoom1701
Mods:
