03-19-2014, 07:54 AM | #1 |
Drives: 2013 1Le Join Date: Feb 2014
NNP with Headers Combo?
I know there is most likely a thread answering this but after reading through the endless threads on Google I could not find any to answer my questions.
I am getting ready to pull the trigger on the ARH headers for my 2013 1Le with the NNP exhaust. I want to keep the NNP and mate the headers up to it. So my question is should I go with the header system that does not come with the ARH Xpipe or should I purchase them with the Xpipe? What are the gains if any and is there a big sound difference with the Xpipe? The few threads I read kind of went back and forth as to if it is worth the extra cash to get the Xpipe. I want the car to run and sound as good as it can once I am done. I will be buying either these without xpipe http://www.apex-speed.com/american-r...hout-cats.html Or these with the Xpipe http://www.apex-speed.com/american-r...hout-cats.html Thanks Chad |
03-19-2014, 08:02 AM | #2 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
if i may be bold and make a suggestion rather than answer your question..............
go with LT (with/without cats, your choice) and see what you think. they bolt right up and if you are not pleased, you can try the x-pipe. to answer your question: only you can decide what is best to you as far as sound. best to do in steps, that way you know what part to change that you don't like. i went with the resonated x-pipe, because i was wanted to remove the last bit of drone in my system. but again, that is what i felt was important.
03-19-2014, 08:14 AM | #3 | |
Thanks! |
03-19-2014, 08:26 AM | #4 | |
Drives: E92 BMW M3 Join Date: Oct 2012
There is no resonator on the LS3 and def not the NPP. I just added headers and considered the resonated x-pipe myself, but wanted to live with it for a while and see how I like it. So far I really love the way it sounds with the headers and high flows, and pretty sure you will too. h018871 has a great suggestion to start with headers and go from there. I am going to see how it sounds with the flaps closed on start up after a electrical modification(with help from an awesome C5 member), and see if a resonator will be a consideration or not. I really dont think you will see much if any gains by adding an x-pipe, from what I understand the factory h-pipe flows very well and little gains are to be had by switching to an x-pipe but your tuner should be the one you ask about that. Good luck with your build!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
03-19-2014, 08:44 AM | #5 | |
Great and I mean great input thank you! I will do just that then start with the headers without xpipe and see how she sounds and runs. If I feel I must have the Xpipe I will do so later on down the road! Thanks Chad |
03-19-2014, 08:44 AM | #6 | |
BTW What numbers did you put down? |
03-19-2014, 09:31 AM | #7 |
Drives: 15 Lexus RCF, 17 Vette Grand Sport Join Date: Apr 2013
I am contemplating the same thing!! I have a set of SW LT no cats sitting in my spare bedroom for over a month!! I am doing my first track day with the car next month. I figured I would drive it stock before I add power. I have been reading about adding the X-Pipe I guess I will just install without and go from there. My wife is already annoyed that the car is going to be louder, however I told her when I got it my goal was to make it sound like a Stock Car
03-19-2014, 09:34 AM | #8 |
I havent gotten it tuned yet, so sadly I dont have any numbers. Also, sadly dont have a baseline dyno number, so nothing to compare either.
03-19-2014, 07:57 PM | #9 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
As you are talking about exhaust, I assume you meant "NPP".
03-19-2014, 08:31 PM | #10 | |
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH Join Date: Jan 2014
Oh, I just clicked on your choices and see you are going catless. Just be ready for a REALLY loud exhaust.
Consensus is, by definition, a lack of leadership.
03-20-2014, 03:57 AM | #11 |
It's all hers.
Drives: 2015 ZL1 Join Date: Jan 2012
For me, once the money was spent when I ordered our 1LE with the NPP I was keeping it. As it sets, current mods, the tune and possible future mods I wouldn't gain any HP by spending even more money replacing it.
As a side note, I'm pulling the JBA shorties & cat-less mids and installing a set of Pfadt LT's & HF cats. With this I'll at least re-coupe some of the cost by selling off the JBA parts, get a retune and pick up a few more HP. That's money worth spending in my book. Replacing an NPP with something else on a mildly modified car isn't worth it.
03-20-2014, 09:22 PM | #12 |
Drives: 2013 Camaro 1LE Join Date: Aug 2013
I put TSP headers on, no cats and also kept the NPP as that was what I wanted after having my droning G8. It sounds great, is quiet when cruising and then all hell breaks loose when you're on the loud pedal! I will be making some gopro vids soon.
http://youtu.be/9wmNMNmwE_k
2013 Camaro 1LE - SLP TVS2300, TSP 2" Headers, CAI, ADM FCM, NPP, Monster LT1 clutch, MGW flat stick, TSP LS3b cam, PAC springs, S&M Motorsports Tuning, 591 hp on Mustang Dyno
2016 GMC Denali 1500 Bulach Racing Team - Home of the fastest manual powered GM car in the world! |
03-20-2014, 11:16 PM | #13 |
Where you getting the Pfadts?
03-21-2014, 08:19 AM | #14 |
I think he has had thema while and been waiting for better weather to install.
