07-08-2014, 12:56 PM | #1 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
69 Z28 recall, no kidding
Sounds crazy, but it happened around 1972. The dealership in Pascagoula, Ms. installed some tie downs around the exhaust manifolds, because the cars were breaking motor mounts. It had a cable on one side and a mounting bracket was added to the other side. The car is currently being restored and I'll post some pictures in the near future!
07-08-2014, 09:31 PM | #2 | |
Drives: 1969 Z/28 + 2015 Z/28 Join Date: Aug 2009
07-09-2014, 10:42 AM | #3 |
Drives: car Join Date: May 2008
Recall was dated Dec 10th , 1971. Lots more than just Z/28s. It was poor design, if the rubber isolator separated from either half of the mount there were no mechanical stops to prevent excessive motor movement. Mounts were redesigned twice for this reason. Quick fix was to install limit cables so the motor couldn't lift too far off the (failed) mount and pull the throttle linkage.
My car still has them on it. Original on left, then 2nd, and third design on right. EDIT: The kit pictured is the small block kit, the kit for the big block had a slightly different bracket that mounts on drivers side exh. manifold. Last edited by MLL67RSSS; 07-09-2014 at 10:57 AM. |
07-09-2014, 10:44 AM | #4 |
Problem was if you hit the throttle hard the motor could lift and pull the throttle linkage to full, and then the linkage could possibly hang up on things keeping it stuck at full throttle.
Recall: Last edited by MLL67RSSS; 07-09-2014 at 10:55 AM. |
07-09-2014, 12:27 PM | #5 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
is there a TSB book on 1st gen Camaros? I have one for the GS cars, it's a fascinating read and it shows what to expect on the cars even today, for example, is a puff of smoke out the exhaust normal each morning on a GS455? Yes actually it is!
07-12-2014, 12:54 PM | #6 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
Funny story - When I got my 69 Camaro back in 1979 I had to tow it home. Once I tore it down and got it running I found this odd little chain wrapped around the drivers side upper control arm shaft and the drivers side exhaust manifold. I could not imagine what it could be for and promptly took it off and tossed it in the trash. I went for a drive and punched it - WHEEEE!!!! the engine lifted up off the broken rubber mount and the throttle was locked to the floor. The car blasted away down the street at wide open throttle. I shut the key off and learned quickly what that silly chain was for. :~D
-Mark. |
07-12-2014, 08:28 PM | #7 | |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
2010 Camaro SS LS3 - No Modz
07-13-2014, 08:18 AM | #8 | |
Buick 455 Fan
07-13-2014, 10:03 AM | #9 |
'69 Owned Since '79
