Old 07-24-2012, 06:21 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Question Thermostat question
Ok so I have been looking for a cool thermostat for my car and ive called everyone even the dealer. Seems the dealer is the only one who can even get one. Does anyone make a cooler thermostat for the V6's?? If not what can I do to drop the temp a little?
2010_camaro is offline   Reply With Quote
Old 07-24-2012, 06:23 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
I would like to know this too....
Edit: If they can make cooler ones for the v8 and doesnt cost a lot my thinking would be they could make them
Lil' Nasty is offline   Reply With Quote
Old 07-24-2012, 06:35 PM   #3
2010_camaro
The dealer wants like 75 bucks for the stock one. it comes with the whole housing.
Old 07-24-2012, 06:46 PM   #4
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Pfft f*ck that if you want a stock one I bet Rockauto has them for cheaper. An aftermarket thermostat for my dads zo6 is 30$ even though its a little different
Old 07-24-2012, 06:54 PM   #5
2010_camaro
I wonder how bad it would be to just do away with it? I run my motorcycle with out one and it runs alot cooler going down the road and never hits above 220 in traffic. Its a high compression motor as well 13.5:1
Old 07-24-2012, 06:57 PM   #6
blackTT600
Drives: 2011 2LT M6 SC
you do that to this car and you will be !!!
motorcycle is/can be air cooled
blackTT600 is offline   Reply With Quote
Old 07-24-2012, 07:37 PM   #7
SC2150
There are no cooler ones available yet that we have found.....and the cost is not the issue, it is app 3 hours of work on a lift to change it. It mounts to the rear of the engine block up against the firewall/trans tunnel.
Old 07-24-2012, 09:07 PM   #8
2010_camaro
Ya because thats where I would put it!
Old 07-24-2012, 09:23 PM   #9
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
why?
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 07-24-2012, 11:36 PM   #10
2010_camaro
cooler motor runs better.
Old 07-25-2012, 05:49 AM   #11
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Most engines do, however, this engine likes it hot with cold air coming in. This has been proven by a few on the dyno, each pull produced more HP as the engine continued to get hotter.
I would not look to change to a cooler thermostat.
Old 07-25-2012, 08:08 AM   #12
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
This... and a cooler engine = more ring gap = less compression.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 07-25-2012, 08:19 AM   #13
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
I wouldn't mess around with it. Engines, particularly today's engines with their much tighter tolerances, are designed to run at specific temperatures, both in terms of performance, and wear. That's why they have thermostats to begin with.
You certainly don't want to take it out entirely. That'll eventually screw a lot of stuff up and cause premature wear, particularly if it stays so cold, it never goes into closed loop.
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 07-25-2012, 08:31 AM   #14
1954 Belair-man
1954 Belair-man's Avatar
Drives: 2010 Camaro IOM 1SS M6
1954 Belair-man is offline   Reply With Quote
