Cold Air Inductions
Old 11-04-2012, 09:34 AM   #1
InfernoMan2011
Drives: 2011 Inferno Orange 1LT
Buzzing sound on acceleration....
I just noticed this the other day. It is intermittent. Whenever I accelerate, when I first take off, I hear a rapid clicking/buzzing sound. I wondering is this is the valve in my RX catch can, as I never heard the sound before. (yes, the hoses are connected right, and I am using the RX Breather cap.) Anybody have any ideas what could be causing this? I am about to drive around the block and watch the RPMs, etc. to provide more detailed info.
-infernoman2011
InfernoMan2011 is offline   Reply With Quote
Old 11-04-2012, 09:46 AM   #2
InfernoMan2011
ok....
Ok, just got back from a drive. Seems the "sweet spot" for this occurence is at about 1000 RPMs, like when slowly rolling up behind traffic at a stoplight.
-infernoman2011
Old 11-04-2012, 11:39 AM   #3
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
can you post a sound clip? Also post all your mods. Auto or manual?
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
Old 11-04-2012, 01:39 PM   #4
InfernoMan2011
Will do...
I will try to get a sound clip and post it up. It's 2011 1LT Automatic. Current mods are:
Vararam CAI (on the car over a year now)
RX Catch can (installed about 2 months ago)
RX Optional Oil Breather cap
I installed the breather cap the same time as the Catch can.
I just did an oil change 2 weeks ago with Mobil1, and drained the catch can when I changed the oil.
-infernoman2011
Old 11-04-2012, 02:29 PM   #5
h2oplay
Winners find a way
h2oplay's Avatar
make sure the drain valve is closed on the catch can, it should be extended down, not up towards the can.
Old 11-04-2012, 03:18 PM   #6
InfernoMan2011
I bet that is my problem! I thought it was dripping some oil from the can, so I "tightened it up", or so I thought!
Old 11-05-2012, 10:08 AM   #7
InfernoMan2011
Fixed!
That was it. No buzzing sound now. I would feel like an idiot, but my catch can came in with no instructions, so I installed based on on threads of others setups here on Camaro5. Other than that I have been more than pleased with the product. Thanks for the quick assistance with this issue!
-infernoman2011
Old 11-05-2012, 04:29 PM   #8
h2oplay
Winners find a way
h2oplay's Avatar
Great news, it's a common mistake, made by the best of us sometimes....
Old 11-05-2012, 06:08 PM   #9
Wuiquen
Wuiquen's Avatar
Drives: 2011 Summit White 2LT/RS
yeah.. dont feel bad about it.. the same happen to me.. I honestly thought it was closed but it wasnt... also, I did had a buzzing sound from the catch can that was produce by the check valve.. it would go away after you step on the gas.. but since I moved it, I dont hear it anymore.. either way, tracy sent me a replacement check valve and a plain fitting too.. they are great whenever a customer has problems.
Wuiquen is offline   Reply With Quote
