JUICEDMOTORSPORTS
Old 02-02-2016, 01:22 PM   #1
TECHTURTLE
TECHTURTLE's Avatar
Drives: 2016 Camaro 2SS
Door Handles $30.00
Picked the set up on Ebay for 30 bucks. They are plastic but so are the ones from Chevy.. Took a total of 10 minutes to install, 5 per side.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added
Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear.
TECHTURTLE is offline   Reply With Quote
Old 02-02-2016, 02:27 PM   #2
bigwayne3000
Drives: 2011 Camaro LS
That actually looks good, nice contrast to offset all the orange. I have an IOM too. Got a link to the seller?
bigwayne3000 is offline   Reply With Quote
Old 02-02-2016, 02:56 PM   #3
TECHTURTLE
TECHTURTLE's Avatar
http://www.ebay.com/itm/371406096852...%3AMEBIDX%3AIT
Added
Old 02-03-2016, 02:36 AM   #4
Graphicsgod
Graphicsgod's Avatar
Drives: 2015 Manual Hot Red 2LS Camaro
Originally Posted by TECHTURTLE View Post
The guy is out of stock :(..
The only ones I could find was these and they are freakin expensive!!
http://r.ebay.com/S36Eit
I did however find these, kinda similar. The more I look at them, the more they are growing on me !
http://r.ebay.com/znhGQO
Wondering if a 2010-13 door handle would work on a 2014-15 Camaro?!?
Graphicsgod is offline   Reply With Quote
Old 02-03-2016, 08:54 AM   #5
TECHTURTLE
TECHTURTLE's Avatar
http://www.ebay.com/itm/281919723856...%3AMEBIDX%3AIT
There are several out there that are selling them separately..
Added
Old 02-03-2016, 04:41 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS and Twin Turbo'd SRT8
I bought the last set after seeing yours last night....
Orange Krush II
1LE Front with DSE Links and Rear Sway Bars, Splitter, 3.91 Gears with 1LE Axles, 14/15 Heat extractor in a 13 1LE hood, 1LE shocks and struts,1LE Suede Flat bottom Steering wheel restitched in orange, Factory Hurst short throw shifter with the Pegasus rear poly shifter mount, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, Skip Shift eliminator, 1LE diffuser with dual mode mufflers, Z/28 headers and Cats, 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers and CTS-V Rotors, PAFDT Solid Cradle bushing, Z/28 Toe Rods and UCA Bushings.
Old 02-03-2016, 04:57 PM   #7
TECHTURTLE
TECHTURTLE's Avatar
Cool! They are super easy to install.
Added
Old 02-03-2016, 07:33 PM   #8
olblue75
olblue75's Avatar
Door handles
Is there any door disassembly required?
Orange Krush II
Old 02-03-2016, 08:09 PM   #9
C4-2014
C4-2014's Avatar
Drives: 2016 CAMARO RS
wicked
C4-2014 is offline   Reply With Quote
Old 02-03-2016, 08:29 PM   #10
TECHTURTLE
TECHTURTLE's Avatar
Nope. There are videos online to show you how. All you need is one torx bit and 10 minutes.
Added
