Old 04-06-2017, 05:35 PM   #1
Official SCT
Drives: n/a
Official SCT Thread
Introducing the Official SCT Thread for SCT Technical Resources. This thread will be monitored throughout the day during normal business hours (9am-6pm Est) however please allow at least 24 hours for a response.
For immediate Tech support please reach us at (407) 774-2447
Official SCT is offline   Reply With Quote
Old 04-12-2017, 11:23 PM   #2
Kens ss
Kens ss's Avatar
Drives: 2011 SS/RS , L99 convertible
Just used my SCT to upload a custom tune. Pretty straight forward. A bit scary uploading to the car the very first time. As one does not know what to expect.
But went well!
Can you explain how and what the data logger can do?
Kens ss is offline   Reply With Quote
Old 04-13-2017, 11:34 AM   #3
Official SCT
Drives: n/a
Our LiveLink software can be used to help diagnose some issues and assist our dealers in remotely writing tunes. You essentially hook a Windows based computer to your tuner and then the tuner to your vehicle. The tuner forwards data to your computer and LiveLink displays it in a more human readable way.
The data that the tuner reads is information your vehicle uses to alter fueling and how it drives. Things like air temperature, pedal position, and intake air flow help determine how much fuel to add to the engine and when to fire the spark plugs. After market parts sometimes alter these expected values in a way that the PCM has trouble deciphering and that's where custom tuning comes into place. A custom tuner can look at air/fuel ratio at a certain RPM and see how much it's off to adjust for something like an after market CAI.
Let me know if this answers your question.
Old 04-20-2017, 02:01 PM   #4
Shane27
Shane27's Avatar
Drives: Black on black 2015 2ss/rs
Where can I find good custom tunes/X4 settings for my L99?
Shane27 is offline   Reply With Quote
Old 04-20-2017, 07:24 PM   #5
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
Talk to Dynosteve on here for a Custom tune to load with your tuner. My L99 kicks now
qcman is offline   Reply With Quote
Old 04-20-2017, 08:37 PM   #6
Kens ss
Kens ss's Avatar
I second the recommendation for dynosteve. He can send an emailed tune to upload to the SCT tuner.
I was blown away by the change in performance. Also turned off the AFM which always annoyed me.
This tune includes tuning the tranny for quicker and firmer shifts.
Old 04-21-2017, 09:36 AM   #7
Official SCT
Drives: n/a
You can also check our website to locate Dealers in your area but since we have so many dealers we really cant choose one over the other.
https://www.sctflash.com/where-to-buy
+ Thanks guys for the suggestion on Dynospeed
Old 04-22-2017, 04:33 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS L99
Word of advice to anyone using an SCT handheld to tune their car:
Make certain your battery is at full charge.
The tuner seems to be very sensitive to anything below full charge. And do NOT touch anything inside the car while the tune is installing. Windows, locks, radio, etc...
If I need to do anything with my X4, I will usually let the car run for a good 5-10 mins to charge beforehand.
2010 Cyber Gray Metallic Camaro 2SS/RS L99 - Texas Speed Longtubes (Catless), Summit X-Pipe, Flowmaster Outlaw Axle Back (w/MBRP GFX Tips), Vararam OTR CAI, Granatelli wires/AC Delco 41-110 Plugs, 160* Stat, LED DRL/Harness, Vitesse Throttle Controller, STOP-TECH Slotted/Cross Drilled Rotors w/Hawk HB453Z.585 Performance Ceramic Pads, ZL1 Leather Steering Wheel, ZL1 Add-Ons Wicker Bill Spoiler, SLP Front Splitter - Tune by DynoSteve
Old 04-29-2017, 08:19 PM   #9
PFL
PFL's Avatar
Drives: Camaro SS
Thank you very much for the forum support. Wanted to know why sct what you say is something that really helps your customers, you do not have the option to read ethanol% or alcohol%. Simply these PIDs do not work for reading. I've already contacted you for customer support, I've spoken to Keith or other support and I've never been clear why Livelink is unable to read E85. I can only do the readings with HPtuners. Could you help us with a solution in your tool?
PFL is offline   Reply With Quote
Old 05-01-2017, 06:57 PM   #10
Official SCT
Drives: n/a
We can get in a ticket to add those for your vehicle. To do so I would need you vehicle's ECU strategy and SWPN (if it's 2011) which is found in vehicle info when hooked up via OBD to the vehicle in question.
Old 05-01-2017, 10:27 PM   #11
PFL
PFL's Avatar
Drives: Camaro SS
My ECU 12639270. These pids are not valid for datalog in Livelink. It is not possible to activate them with my ECU 12639270. I hope you solve this problem. All 2011 car models and other models are impossible to make reading fuel alcohol content and alcohol%.
Old 05-02-2017, 09:00 AM   #12
Official SCT
Drives: n/a
With that being a GM I'll be needed the year, make, model, and engine size as well. I know we have that PID for newer ecoboosts so it should be something we have on the GM side moving forward.
Old 05-02-2017, 07:03 PM   #13
PFL
PFL's Avatar
Drives: Camaro SS
I Have Camaro SS year/model 2011, automatic transmission, engine 6.2 ls3 , L99 ECU system.
I'm very upset about livelink not giving this support. Honestly if I knew I would need the hptuners to do the E85 reading I would not have bought the x4 sct. But I have hope that you will adjust the Livelink for reading E85. Many guys are doing E85 conversion, this PID is indispensable for custom tune and customer safety.
Thanks
Old 05-03-2017, 09:16 AM   #14
Official SCT
Drives: n/a
I double checked the available PIDs for this vehicle before submitting the ticket and found the following.
Make sure you have DB version 106 or newer and those should be showing up for you. Depending on how old the database is you may have to uninstall and install a fresh download from our website to get it to properly update. You can download LiveLink from this link
https://az824306.vo.msecnd.net/softw...ink_Gen-II.exe
