11-15-2017, 06:58 AM | #1 |
Drives: 2011 2SS/RS Join Date: Nov 2011
P0556 Brake Booster Pressure Sensor Circuit Range/Performance?
Camaro is throwing this code. Any idea what this is?
11-15-2017, 03:13 PM | #2 |
Typically happens when adding a supercharger.
Tell us more about your build.
www.jannettyracing.com
11-15-2017, 06:32 PM | #3 |
Drives: 2024 Nitro Yellow 1SS 1LE Join Date: Jun 2016
Listen to this guy, he knows his s..t!
11-16-2017, 08:03 AM | #4 |
11-17-2017, 04:28 PM | #5 |
Wife’s car, totally stock. Plus another message in message center says open and close window...doesn’t go away after doing so.
11-22-2017, 10:32 AM | #6 | |
you will have to cycle both windows, when you do hold the button at the bottom for 3 seconds then the top for 3 seconds. Totally stock you likely have a vacuum leak or a bad sensor. Ted.
11-22-2017, 05:46 PM | #7 |
Thanks, will try that!
