08-22-2017, 06:07 AM | #1 |
Drives: 2010 SS Join Date: Feb 2017
New Powder Coat RJT
I just got these jewels from THP Coatings! They are going on tomorrow!
08-22-2017, 07:19 AM | #2 |
Drives: 2012 2SS/RS LS3 Join Date: May 2012
Very nice!
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA Kooks 1-7/8" LTs w/ Cats Roto-Fab, Bo White TB, Borla Touring Catback 3.91 1LE Gears, MGW Tuned by Pat G |
08-23-2017, 01:22 AM | #3 |
What is the procedure for powder coating? Is it simply taking off the old calipers and then powder coating it and then putting it back on? Or do the calipers have to be disassembled? Looks great by the way!
Rotofab CAI, VMAX PTB, Borla S axle-back, Dynatech SuperMaxx 1 7/8" headers/HF cats, No weeds exhaust diverters, Apex air scoop & catch can, Rohana wheels, MPD1 Z-Force Hood, BTR Stage 3 cam, Vitesse Throttle Controller, etc...
08-23-2017, 07:30 AM | #4 |
08-23-2017, 08:09 AM | #5 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Disassemble clean/sand blast/clean/coat/cook/cool. Reassemble with new seals and boots and reinstall.
Orange Krush II
08-23-2017, 10:04 AM | #6 |
Drives: 2013 Camaro SS Join Date: Oct 2016
Those look amazing. Is it a translucent red paint? How did you get the lettering black?
08-23-2017, 12:19 PM | #7 |
08-23-2017, 02:34 PM | #8 |
Drives: 2011 procharger ss Join Date: Sep 2015
Silver metallic base coat, lollypop red tinted clear top coat over black vinyl decal. We do basic colors with vinyl decals, custom colors in base coat and use decals as stencils.
Olblue is correct. It is actually a lot of work for each set by the time they are done. Clean, chemical strip if already coated, sandblast, disassemble, clean, outgas aluminum calipers for a hr, mask, clean, coat, apply decals, clear, rebuild, package, ship.... We try to do 3-5 sets of similar colors at the same time to make better use of our small oven and get through the orders in a decent time. |
08-23-2017, 07:15 PM | #9 | |
I can't get over how good a job you did. What would you charge if I pulled mine and shipped them to you? How long to turn them around? This could be a winter project. |
08-24-2017, 08:12 AM | #10 | |
Thanks, Kevin |
08-24-2017, 08:13 AM | #11 |
They are on!
01-14-2018, 10:50 PM | #12 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2011
How close do you think the color is in person? Looks a bit bright. I'm sure pictures don't do it any justice. I'm looking to do this
01-15-2018, 05:49 AM | #13 |
It's not a perfect match, when the car is clean is a little closer match. But a man running for logos life will never notice it!
01-15-2018, 06:26 AM | #14 |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
Kevin done the very same color on my Brembo's. I am running them on my Ashen Gray Metallic Camaro, really like the looks behind the 21" wheels.
The amount of work and time that goes into "properly" preparing, coating and then rebuilding a set of Brembo brakes your so far better off sending them to someone that knows what they are doing. TPH does a fantastic job, thanks again Kevin.
