Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 09-19-2013, 08:27 PM   #1
RobZL1580
Drives: 2013 Camaro ZL1
Continental ExtremeContact DWS - All Season
Do these look as good on the ZL1 as the stock Goodyear tire?
Does anyone have some good pictures of their ZL1 with these tires mounted on the optional bright forged aluminum ZL1 wheels?
Thanks, Rob
RobZL1580 is offline   Reply With Quote
Old 09-20-2013, 02:13 PM   #2
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
Aestetics are really not a consideration.
If you want good all-season tires in almost-stock sizes, those are them.
Sexy or not.
I will be getting mine soon.
2014CamaroZL1 is offline   Reply With Quote
Old 09-20-2013, 03:41 PM   #3
RobZL1580
Sexy or not.
I would still like to see a picture of the car from the side so I can see how much gap is between the tire and sheetmetal along with what the sidewall of the tire looks like.
Thanks, Rob
Old 09-20-2013, 03:59 PM   #4
crangie
crangie's Avatar
Drives: Camaro ZL1 #641
here some pics on the black wheels. should be no difference on the silver wheels. http://www.camaro5.com/forums/showth...38#post5727038
crangie is offline   Reply With Quote
Old 09-20-2013, 07:41 PM   #5
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
How are yours holding up to the power? How many miles do you think you can get out of them?
Do you think a staggard setup is an okay way to go or would it be better to put them on a square setup so you can rotate them?
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 09-20-2013, 07:51 PM   #6
2014CamaroZL1
Thanks for the pix, crangie.
Personally, I will stay staggered.
It is bad enough to put worse handling tires on the car.
At least going +1 in the back will compensate a tiny bit.
Or...if you don't mind mixing tire manufacturers front to back,
you can get stock size fronts in Dunlop SP Sport or Michelin Pilot Sport A/S3.
Final item...The stock tires have load ratings of 100 front and 104 rear.
If you downsize the rear tires, it may be tough to find a 104 rating in a tire that you want.
One tire vendor would not sell me a tire for the rear of a ZL1 that was not rated 104+.
I was investigating spare tire options at the time.
Old 09-20-2013, 09:09 PM   #7
RobZL1580
Thanks for the pictures. They look great!
I think the Continental tires have a load rating of 110 for the fronts and rears.
I spoke to someone at TireRack today on the phone and he said if you are using the stock rims, he recommends the 275 on the front and 315 on the rear. He said do not put the 275 on the rear because the tire is not wide enough for the stock rear rims.
Old 09-20-2013, 09:51 PM   #8
rvnmaniac
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300
Sexy or not.
rvnmaniac is offline   Reply With Quote
Old 09-20-2013, 09:57 PM   #9
rvnmaniac
Yep that is my plan 275/40 F & 315/355 R. Purchased a set of ZL1 replica rims. Got the OEM TPMs and a set of Gorilla Lugs for after market rims. Just looking for a good price on the Continentals. Got to do it before the end of October. Don't plan on driving in the snow but definitely when it gets cold.
Old 09-21-2013, 03:20 PM   #10
djnice
djnice's Avatar
Why gorilla lugs for aftermarket rims? I was wondering which ones to get. Aren't the replica's the same as OEM?
Old 09-21-2013, 03:37 PM   #11
rvnmaniac
You don't HAVE to purchase "Gorilla" lugs but of course you need 14mm x 1.5 lugs. Check out this thread. There are lugs for OEM & aftermarket they are different. I purchased both styles. For my OEM & aftermarket ZL-1 Wheels.
http://www.camaro5.com/forums/showthread.php?t=95097
Old 09-23-2013, 12:01 PM   #12
2014CamaroZL1
The lug nut seating surfaces are typically different between OEM and aftermarket wheels.
Thus the need to use aftermarket lug nuts with aftermarket wheels.
Old 10-03-2013, 11:53 PM   #13
Smuuth
Smuuth's Avatar
Drives: 2017 Hyper Blue Metallic ZL1
Thanks, Rob
Here is my ZL1 with the Continentals mounted on Factory Reproduction Style 41 wheels.
Smuuth is offline   Reply With Quote
Old 10-04-2013, 07:19 PM   #14
notagoat
notagoat's Avatar
Drives: 2015 BMW M4
DSWs on ZL1 Bright Wheels
I have had these tires for around a year. They look fine, extra wide out back. I went with 275/35/20 in the front for better steering feel and my car is lowered so the extra sidewall would be too much. I only got 15,000 miles out of the rears, not enough for an all season tire so I am swapping them out for Micheline Super Sports even though the fronts have tons of tread left (I live in FL, it dosn't get cold).
Here are the pics you asked for, let me know if you want the fronts.
notagoat is offline   Reply With Quote
