08-01-2011, 09:54 AM | #1 |
Suffers Fools Poorly
Drives: 2010 SS/RS, CGM w/ Silver Stripes. Join Date: May 2011
WTF stabilitrac
So I'm on my way to work. I have the cruise set at 53. Flat level road. A little moist but not wet. Anyway, the cruise flicks off, there's a tick like the power went out, three bells and the six flashed "service stabilitrac" then it went away. This all happened in like a second and was gone. No other problems this morning. Weird.
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot. |
08-01-2011, 10:02 AM | #2 |
"First There"
Drives: 2010 camaro 2ss Join Date: Feb 2011
my guess is computer turned off cruise control so that it could keep you from spinning out....sounds like it worked as advertised
08-01-2011, 10:10 AM | #3 |
Spin out on what? It was in sixth gear at 53 mph on a level straight road.
08-01-2011, 10:15 AM | #4 |
"First There"
said the road was moist right?....even thats enough to get the oil to the surface and make it slippery
08-01-2011, 11:24 AM | #5 |
It rained the night before. No standing water. It's was in 6th gear and what...1200 RPM or something low? Somehow I doubt it had enough power to break loose.
08-01-2011, 02:14 PM | #6 |
Drives: '11 2SS/RS RJT M6 Join Date: Oct 2010
Owner's manual page 8-34
"When the system activates, the StabiliTrak/Traction Control System (TCS) warning light flashes on the instrument panel cluster. You may also hear a noise or feel vibration in the brake pedal. This is normal. Continue to steer the vehicle in the intended direction. If there is a problem detected with StabiliTrak, a Service StabiliTrak message displays on the DIC and the StabiliTrak/TCS warning light on the instrument panel cluster comes on. When this message and warning light displays, the system is not operational. Driving should be adjusted accordingly." Sounds like your stabilitrac kicked in then the system found a momentary error that went away. I don't know if the one of the control modules logs stabilitrac errors but I would take it to the dealership to find out.
Vararam CAI, Elite Engineering Catch Can, Separate Clutch Fluid Reservoir, Ghost Armor Full Protection Package, Chromed Turn Signal Bulbs, RPI Stealth Splash Guards, Skip Shift Eliminator, Defenderworx Chrome Bowtie Inserts, Pfadt Trailing Arms, Camaro Decal Store CGM Hood Spears with "376ci" custom text, Billet Depot/Drake Underhood Polished Caps, CGM Lug Nut Decals, Pedders Front Radius Rod Inserts, JacFab Front License Plate Bracket
08-01-2011, 08:00 PM | #7 |
Drives: 2010 2SS Join Date: Apr 2010
I had the stabilitrac warning come on for no reason and then go off a few times. Just cruising at a steady speed. An engine "miss fire" detection, an errant "G switch", computer, and who knows what else can cause this.
09-09-2011, 01:32 AM | #8 | |
Turned out to be a bad BCM (body control module) |
09-10-2011, 11:59 PM | #9 |
Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
While tuning the only thing the car does is beep three times and display stabilitrac in dash when computer restarts. Not that your computer shut off. It could not. Just thpught it was interesting.
10-12-2011, 12:24 AM | #10 |
Jeff
Drives: 2010 Camaro SS/RS Join Date: Feb 2010
Not sure if this will help, but just keep it mind to have it checked out next time at the dealer. I have been fighting the "Service Stabilitrak" light for about 11K miles or so. Just now starting to get to the bottom of it. One trip to the dealer, they discoverd that the wiring harness was partially unplugged, but the light came back on afterwards. Today, they discovered that the steering wheel angle sensor is bad. Hopefully, this will take care of the light. I have had it serviced numerous other times, but no real reason to the cause. A low voltage reading appeared one time doing the diagnostics, but the light continued to come on. So, I will coninue to take it to the dealer in hopes of finally eliminating all the possible causes. It just makes me wonder how many other things are partially unplugged or bad on the car.
Similar Threads | ||||
WTF kind of ticket is this>=) | sangerbanger58 | USA - California | 111 | 07-28-2011 11:16 PM |
WTF California...WTF? | Mindz | Off-topic Discussions | 71 | 02-26-2010 03:02 PM |
WTF!!! YOU ARE KIDDING ... RIGHT? | Matrix | Off-topic Discussions | 20 | 02-19-2010 03:58 AM |
24 hours old,back in shop wtf | salvie87 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 1 | 06-28-2009 12:10 AM |
Insurance WTF? | ZeeTwentyFour | General Automotive + Other Cars Discussion | 8 | 03-27-2009 10:38 PM |
